Old 01-14-2021, 04:06 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Originally Posted by joeko23 View Post
Thanks John, I’ll try to push it out. Just don’t want 1/4” of body filler. That’s sure to chip off. Thanks!
That's why I used the Eastwood body solder to build up my passenger fender, because I knew to much filler isn't good. Tends to shrink over time as well. At lease the solder is actual metal, and won't shrink.
Is your fender an aftermarket one?
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 01-14-2021, 07:05 PM
joeko23 joeko23 is offline
Yes aftermarket doors and fenders. The peak bows in where it meets door to fender. If I add filler or metal it will then rub on the inside of the fender when I open the door. The body shop that was undercoating and painting firewall suggested to cut the edge of the peak and pull it out. Then weld it. That’s the only way they said it won’t rub.
Old 01-14-2021, 07:15 PM
dhutton dhutton is online now
I have had to cut the inner edge brace of the fender to get the shape correct. Then reweld the cut once you have the shape you need.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
Rodknock (01-15-2021), waynieZ (01-14-2021)
Old 01-14-2021, 08:11 PM
I agree with Don, that way you still get the stiffness you need to hold the fender shape and you get the room you need.
The Following User Says Thank You to waynieZ For This Useful Post:
Old 01-15-2021, 07:34 PM
Rodknock's Avatar
When I was having issues with an AMD driver fender, I had a guy tell me the same thing. He said cut the brace in the back by the "V" in the fender, and it will cause it to basically "relax" into place.
I ended up finding an OEM fender, so I didn't have to deal with that issue.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 01-15-2021, 08:04 PM
Rodknock's Avatar
Default Fixing the droopy eye
This is an issue that has plagued me from the start. Trying to fix the droopy eye, which seems to be a common issue on 69's on the driver side especially. Don't know why. When I had an AMD fender it was even more pronounced. Not quite as bad with an OEM fender.
The fix was so simple, I don't know why I didn't do it before. Just a little cut with a cutoff wheel, move it down, and re-weld. 10 minute fix.
Here's how it was before. It was way worse at one time, but some tweaking and pulling got it close. I'll post a pic of the original issue before the OEM fender first, so you can see how bad it was.
Here's the only pic I had. Even though the grille isn't bolted in, you can see the extreme angle it has.
Here's how it looked before the easy fix. I was almost willing to "live with it" till I tried one last thing.
Here's where I made the cut, and welded back together.
The final outcome, and a comparison shot. I even did the passenger side, just to flatten it out a little more.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 5 Users Say Thank You to Rodknock For This Useful Post:
camcojb (01-15-2021), dhutton (01-16-2021), Roscoe03 (07-21-2023), syborg tt (12-08-2024), waynieZ (01-15-2021)
Old 01-15-2021, 09:26 PM
Nice job, that looks a lot better, and will make your life easier.
Rodknock (01-16-2021)
Old 01-16-2021, 09:27 AM
Rodknock's Avatar
Thanks Wayne. Today, I'm going to try to do the RS headlight stuff. Get things cleaned up and test fitted.
I didn't want to go to work today, so I had a case of anal glaucoma
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following User Says Thank You to Rodknock For This Useful Post:
waynieZ (01-23-2021)
