Old 01-19-2021, 11:21 AM
camcojb camcojb is online now
Originally Posted by k7king View Post
Ok.Thanks I've intalled a few gm crate engines with gmpp computers and used the fan wire from the gmpp harness but there isn't a way to tell it when AC is turned on unfortunately.
You can use a trinary switch on the a/c line, so the computer controls the fans whenever the a/c is off, and once the a/c is on the switch bypasses the computer control and turns the fans on automatically. I'm going to be using a standalone PWM controller for my twin Ron Davis fans.
https://lateral-g.net/forums/showthread.php?t=58472
Old 01-19-2021, 01:05 PM
cpd004's Avatar
cpd004 cpd004 is offline
Correct me if I'm wrong, but the GM ECM doesn't use a trinary switch when controlling fans by way of PWM.
1971 Firebird
2017 SS
Old 01-19-2021, 01:17 PM
Blackhawk's Avatar
Blackhawk Blackhawk is offline
Doesn't get much cleaner than this, the wheel fitment is also perfect! Can't wait to see how it does on the street & track.
Old 01-20-2021, 07:20 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Mark have ever had issues with the latch in the hood popping open at high speeds? I'm not sure if your using the original latch mechanism. I've noticed many car builders use hood pins and my father before me has warn me about the risk at high speeds. thanks sir.
1967 Camaro RS
1969 Camaro coupe
The Following User Says Thank You to 67_camaroRS For This Useful Post:
TT302Z28 (01-24-2021)
Old 01-21-2021, 06:57 AM
Stielow's Avatar
Stielow Stielow is offline
I don’t like the look or function of hood pins. I have run a stock hood latch on most of my cars.
We ran a test at work to see the force on a hood latch on a 2008 CTSv at 190 mph. It was over 300 lbs of force trying to pull the latch open.
I have not had an issue with the stock latch with my Carbon Fiber hood. But we have a big steel reinforcement plate in the hood that the latch bolts into.
If you want to be 100% sure do some old school hood pins. I personally hate them.
I can say at 170 mph in my cars you can see the corners of the hood being forced up by the under hood pressure. Another reason I have hood vents.
Good luck!
Mark
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
camcojb (01-21-2021), fleetus macmullitz (01-21-2021), syborg tt (01-21-2021), waynieZ (01-24-2021)
PTAddict PTAddict is offline
Default Dash
Mark,
I like the finish on your dash - is that just an off the shelf crackle paint or something else?
This build is beautiful. So right in a subtle way, and not overdone. As someone who is trying to emulate much of what you've done in recent builds, one of the hardest things is to keep things simple and logical in both function and appearance.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 01-21-2021, 09:51 AM
Stielow's Avatar
Originally Posted by PTAddict View Post
Mark,
It is our local powder coater wrinkle black powder coat. I like it. It does not scratch and gives a nice look.
Thanks, for the complement. I like simple complex things. This car has a lot going on but it looks fairly simple.
Matt and the gang at Sled Alley do a fantastic job with all the little details.
Mark
Stielow Engineering
The Following 8 Users Say Thank You to Stielow For This Useful Post:
bluesmoke (02-17-2021), fleetus macmullitz (01-21-2021), kwhizz (01-22-2021), PTAddict (01-21-2021), redfire69 (01-21-2021), Rodknock (01-21-2021), waynieZ (01-24-2021), WILWAXU (01-21-2021)
Old 01-21-2021, 10:54 AM
67pro-street 67pro-street is offline
This is an incredible build! I can't even begin to imagine the amount of engineering and thought that went into this, but it looks just absolutely beautiful!!
-Aman
1969 Camaro Z/28: W.I.P. Bolt-on Art Morrison MaxG Chassis, LS2 Stroker, 6spd. manual, amongst many other goodies!
