Old 01-26-2021, 06:28 PM
dhutton dhutton is offline
Yes. You could double check with Carl. He’s very helpful.
The Following 4 Users Say Thank You to dhutton For This Useful Post:
camcojb (01-26-2021), CarlC (01-27-2021), JKnight (01-27-2021), kwhizz (10-07-2023)
Old 01-27-2021, 07:36 AM
BigBronco's Avatar
BigBronco BigBronco is offline
Agreed. Should be able to use it with no issue but Carl makes the process real easy.
2022 F-350 Tremor | Daily Driver
1972 Nova | LSX | 6 Speed | Speedtech Suspension | C6 z06 Brakes | Forgelines
1968 Firebird | LM7 Swap | 4L60e | Ridetech Suspension | C6 Brakes
2012 Corvette ZR1 | Bolt-Ons | Forgelines
2001 Trans-Am WS6 | Cam | Six Speed | Slow
1969 Mach 1 Fastback | New Project
The Following 3 Users Say Thank You to BigBronco For This Useful Post:
Old 01-27-2021, 08:05 AM
CarlC CarlC is offline
The Rick’s Restomod tank, GM Gen5 fuel module, and VaporWorx controller will work well with both setups.
Though a bit more expensive the Gen5 ZL1 fuel module will allow room for up to 750NA HP with no drawbacks when combined with the PWM controller. It will also handle up to 650 supercharged horsepower, so if the forced induction bug hits you're likely covered.
The PWM kit that should work well: https://www.vaporworx.com/shop/product/pwzl13b-tm/
Helpful fittings that usually make installing the fuel pressure sensor into the fuel line easier: https://www.vaporworx.com/shop/produ...outlet-kit-45/
Feel free to reach out at any time with questions.
http:www.vaporworx.com
The Following 3 Users Say Thank You to CarlC For This Useful Post:
camcojb (01-27-2021), JKnight (01-27-2021), WILWAXU (01-27-2021)
Old 01-27-2021, 05:26 PM
JKnight JKnight is offline
Thanks Carl (and Don) Glad to hear the fuel system might be one part I don’t have to re-do if this SBC doesn’t work out!
