Old 05-12-2021, 10:39 AM
paulk68 paulk68 is offline
Wondering if you guys needed to shim this starter at all? I am getting ready to install mine this weekend. thanks
Old 05-12-2021, 12:17 PM
dhutton dhutton is offline
Hi Paul. I have never had to shim an LS starter.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (05-12-2021), Che70velle (05-13-2021)
Old 05-12-2021, 12:34 PM
Don, you are always so helpful thank you so much!
Old 05-12-2021, 04:15 PM
hi paul. I have never had to shim an ls starter.
x2...
Old 05-15-2021, 09:30 AM
572Camaro's Avatar
I love powermaster starters over GM.
I have no experience with LS motors.
I run BBC.
That being said,
My first GM starter was axially offset and no shimming could fix it.
I went with Powermaster because:
1. I can adjust axial offset.
2. I can clock the starter.
3. I can use all three bolts to secure starter to block.
(I just bought a new AC/Delco starter for my zero turn and it has a stamp:
Made in Korea)
Powermaster rules.
Old 05-15-2021, 10:30 AM
For LS engines the factory starters work great and they are affordable. No need to go with anything else imho.
Che70velle (05-16-2021)
Old 05-15-2021, 09:27 PM
randy randy is offline
Factory starter and heat shield
The Following User Says Thank You to randy For This Useful Post:
Old 05-16-2021, 01:11 AM
Did some quick checking and for the starter the other part numbers are (Saving for as much my information as anyone else):
12617229 ACDelco GM Original Equipment Starter
12101763 Pigtail CONNECTOR
11610787 Starter BOLT Qty 2
11571131 Shield BOLT Qty 3
12629286 SHIELD
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following 3 Users Say Thank You to will69camaro For This Useful Post:
camcojb (05-16-2021), Che70velle (05-16-2021), Spiffav8 (05-16-2021)
