I love powermaster starters over GM.
I have no experience with LS motors.
I run BBC.
That being said,
My first GM starter was axially offset and no shimming could fix it.
I went with Powermaster because:
1. I can adjust axial offset.
2. I can clock the starter.
3. I can use all three bolts to secure starter to block.
(I just bought a new AC/Delco starter for my zero turn and it has a stamp:
Made in Korea)
I realize this thread is old but wanted to add this bit of info. If you're using an early Quicktime bellhousing for a Magnum transmission with a *round* hole for the starter, an LS3 starter may cause some interference to fit. The earlier LS1 starter mounts about 1/8" differently and fits perfectly to both the engine, flywheel, and bellhousing. Later Quicktime bellhousings have an oval opening for the starter so the LS3 starter will fit, no problem.
The Following User Says Thank You to pannetron For This Useful Post:
