Old 05-05-2021, 06:52 AM
Thanks they had me wondering, but they fit well.
Old 05-05-2021, 11:21 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Quick question, is that the standard DSE mini-tub kit and directions that those tires fit into or did you do something extra?
Erik
69 Camaro
Old 05-05-2021, 05:12 PM
My car rebuild was done by Mike’s custom Cars he did the DSE mini tubs the way they instruct you to do. He had me order the wheels and built the rear to what he figured from having the wheels. He got it perfect. I haven’t trimmed the wheel well lip and it looks good to go. If I lower the car I’ll have to check again to make sure.
Old 05-06-2021, 04:30 AM
dhutton dhutton is offline
Hi Wayne. How much clearance do you have to the inner wheel housing?
Old 05-06-2021, 11:28 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Looks great Wayne. I just got my tires mounted to my new rims as well. The 345 is a very tight fit. I'll have to trim the outer lip a little, I think.
I have about 3/8" on the inside, although the pic makes it look tighter.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 05-07-2021, 04:27 PM
I got some pictures of the frame connector brackets welded to the sub.
He has more welding and then dress them up
The Following User Says Thank You to waynieZ For This Useful Post:
camcojb (05-07-2021)
  #1257
Old 05-14-2021, 07:35 PM
Hi Don here is a picture of the distance from the frame to the tire.
The welder @akuma.fab said the distance was about 3/4" at that spot of the picture and up above at the closest is 1/2".
dhutton (05-15-2021)
  #1258
Old 06-04-2021, 08:26 PM
I just got some pictures of the work on the exhaust, he made an X pipe to fit around the 4l85. Here's a few pictures.
Here are a few pictures of it where it's going on the car.
This has me concerned. I'm planning to have the exhaust coated, I don't think they can do anything for the the flex coupler. I'm going to make a heat shield if there's room, I'll also put heat shield over the trans cable.
Some of his TIG work.
The Following 7 Users Say Thank You to waynieZ For This Useful Post:
572Camaro (06-07-2021), camcojb (06-04-2021), fleet (06-07-2021), Rodknock (06-05-2021), Sonar Chief (06-07-2021), syborg tt (11-19-2021), TomM (06-05-2021)
  #1259
Old 06-05-2021, 09:07 PM
Rodknock's Avatar
Looks fantastic!!!
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Old 06-06-2021, 10:08 PM
The X pipe fabrication looks top notch, but it appears to neck the exhaust down to basically single exhaust.
The Following 4 Users Say Thank You to Vegas69 For This Useful Post:
dhutton (06-07-2021), EVIL SS (06-07-2021), Tinker (06-08-2021), waynieZ (06-08-2021)
