Old 08-19-2019, 11:58 AM
orangevert's Avatar
orangevert orangevert is offline
Default Ring Brothers bumpers
Originally Posted by redfire69 View Post
A couple more of the rear bumper...
Do they fit that nice, or did you have to massage them? They look great.
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 08-19-2019, 02:16 PM
redfire69's Avatar
Hi Kirk,
I did have to massage the area at the quarter panel mount to flatten where the metal is raised at the bumper mounting hole. Basically, I sectioned the mount hump, flattened it, and re-drilled the hole. So putting the bumper on a finished car might mean modding the bumper instead. It is a really nice part.
Ron
Thanks Kirk
Ron
69 Camaro Redfire
The Following User Says Thank You to redfire69 For This Useful Post:
orangevert (08-19-2019)
  #143
Old 10-03-2019, 02:17 PM
redfire69's Avatar
Fuel and brake lines run, console and shifter holes located, almost ready to stab engine!
Ron
69 Camaro Redfire
The Following 4 Users Say Thank You to redfire69 For This Useful Post:
130fe (10-11-2019), fleetus macmullitz (10-11-2019), Roscoe03 (07-13-2021), syborg tt (10-03-2019)
  #144
Old 10-03-2019, 06:59 PM
Very Nice!
The Following User Says Thank You to waynieZ For This Useful Post:
redfire69 (10-04-2019)
  #145
Old 10-10-2019, 11:27 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
More progress, assembled engine, BBC mild build 400HP/500TQ, should be very streetable...
Wow, I like the choice of sticking to an old school brute big block chevy. What brake booster and MC are you running?
1967 Camaro RS
1969 Camaro coupe
The Following 2 Users Say Thank You to 67_camaroRS For This Useful Post:
fleetus macmullitz (10-11-2019), redfire69 (10-11-2019)
  #146
Old 10-11-2019, 12:36 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Car is looking sweet!
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
  #147
Old 10-11-2019, 06:14 AM
redfire69's Avatar
Thanks! I'm using the S10 master cylinder AC 18M974, tuff stuff booster 2229NC, rod kit 4750, and DSE booster bracket 050302.
This setup would be close to the old DSE kit. The hole in the firewall needs to clearanced in a oval shape for the M/C boot. Links below:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
or
https://www.summitracing.com/parts/ado-18m974/overview/
https://www.summitracing.com/parts/tff-2229nc
https://www.summitracing.com/parts/tff-4750
https://www.summitracing.com/parts/dsr-050302/overview/
Ron
69 Camaro Redfire
Old 06-10-2021, 07:08 AM
redfire69's Avatar
So I'm back at it and I've got the dash cluster loaded with Dakota Digital gauges. I used a heater delete panel and mounted my VA heater controls which I think turned out pretty good. I got the idea for mounting the BIMs on ABS from Mark S.
Ron
69 Camaro Redfire
  #149
Old 06-10-2021, 07:39 AM
redfire69's Avatar
A couple pics of the dash wiring harness done, cluster installed with disconnects. Steering column, shifter, VA heater, and BIMs wired.
Ron
69 Camaro Redfire
The Following 3 Users Say Thank You to redfire69 For This Useful Post:
camcojb (06-10-2021), dhutton (06-10-2021), Roscoe03 (07-13-2021)
  #150
Old 06-11-2021, 08:40 PM
Glad you're back on it! Good luck with it.
redfire69 (06-12-2021)
