Old 07-20-2021, 08:39 PM
Build-It-Break-it's Avatar
There's also an ebay seller that sells one for a smaller diameter harness(for Hondas) that I'm going to be using on my main vehicle harness. The item is listed under "k tuned firewall grommet" . I would post a link but I hate posting up links then they expire.
Ahmad B
Old 07-29-2021, 07:44 AM
syborg tt's Avatar
Got mine the other day and it will be mocked up this weekend and then off to get Anodized black.
marty-mj
Old 07-29-2021, 11:32 AM
jmac jmac is offline
These are very cool. I see on his website there's an option for hidden or visible fasteners, which one do you have there? I was looking on his site but see no way to contact him to ask. I'd like to see a version of both of I could.
Thanks!
My 1967 Camaro
Old 07-29-2021, 12:02 PM
syborg tt's Avatar
Thanks!
So the pictures I posted are the hidden hardware version as you have to tighten the nuts from inside the car.
And the version that Ahmad B posted is the version with the bolts inside the engine bay.
marty-mj
Old 07-29-2021, 01:39 PM
Thanks for clearing that up for me. Think I'm going to go with the visible fasteners for ease of installation, plus where I intend to mount them, you won't see them anyways.
My 1967 Camaro
Old 07-30-2021, 06:47 AM
syborg tt's Avatar
You're welcome and glad I could help
marty-mj
Old 07-30-2021, 02:10 PM
The firewall grommet is actually easier to install with the hidden fastners. With the exposed fasteners you'll need 2 people to install it
Ahmad B
Old 07-30-2021, 06:53 PM
Maybe I'm confused on the orientation? I would think either one would need 2 people to assist unless you can reach the other side of the panel you're putting this on.
For example, placing one of these in the firewall with the hidden fasteners, you'd need someone on the engine side to hold the billet piece in place and then someone on the interior to start the bolts.
With the visible fasteners you'd need someone to put the nuts on the bolts on the interior side.
I was thinking of using those threaded nut inserts that are like rivets to thread in to, or tacking on some nuts to be able to catch the bolts.....
My 1967 Camaro
Old 07-30-2021, 07:12 PM
Can someone please tell me the outside diameter ?
Old 07-30-2021, 10:31 PM
The weight of the engine harness and studs going through the firewall will hold it enough to place the nuts on and tighten it inside the interior. I did it the other day solo.
Ahmad B
The Following User Says Thank You to Build-It-Break-it For This Useful Post:
syborg tt (08-02-2021)
