Old 08-07-2021, 06:11 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Nice fab work...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-07-2021, 06:37 PM
garickman garickman is offline
Originally Posted by 214Chevy View Post
Nice fab work...
Thanks! Your build is pretty amazing, I have followed it since the begining. I am running the same firewall as you. I did modify it slightly because I am running the Wilwood pedals with the triple master cylinders. Here are some random pics of the install.
Greg
The Following User Says Thank You to garickman For This Useful Post:
syborg tt (04-09-2022)
Old 08-07-2021, 06:57 PM
Nice build Greg!!
garickman (08-07-2021)
Old 08-07-2021, 08:12 PM
Opened up the stock lower valance for better cooling. The sides will allow air to the front brake ducts and the center will get air to the oil and power steering coolers. Wanted to leave the parking light/turn signals in the same location as stock so we just cut around them.
Greg
Old 08-07-2021, 08:27 PM
I knew I wanted to run some yellow fog lights in the location of the original parking light/turn signals but I wasn't sure how I was going to do it. I ordered a set of yellow fog lights for a stock Jeep Wrangler. The original opening for the lights was about a 1/2 larger than the Jeep lights. Wasn't sure of the best way to close this gap so I bought a set of 5 inch into 4 1/2 diesel exhaust pipe transitions and grafted them into place. Then fabbed some mounting tabs to attach the fog lights and keep them adjustable.
Greg
Old 08-07-2021, 08:36 PM
Now that I was running fog lights, I need a new place for turn signals. I sketched out an idea for some one-off billet housings which would hold a switch back turn signal/DRL. I sent them to Jonathon at Sparc Industries and he machined up a set of lights that "float" in the center of the brake duct openings.
Greg
Old 08-07-2021, 08:45 PM
It's a little bit hard to see, but if you look at that last picture of the front end you will see that the bumper "fangs" that normally highlight the license plate area have been moved outward and now highlight the foglight area. We used three bumpers to make the one on the car now.
Greg
Old 04-29-2022, 02:49 AM
I like the hood adjusters on the truck. Slick idea but how do you plan for rain runoff? Do you plan on a drain tube? If you would off left a lip or seal it off flush. What’s your plan?
Thanks,
Jimbo
Old 04-29-2022, 07:01 AM
Thanks,
Jimbo
It is hard to tell in the pics, but the area around the hood bumpers is slightly raised to form a small crown. The body filler defined the crown a little bit more. We ran a small stream of water down the channel on each side of the trunk and the water never did climb the crown, it just went right around.
Greg
Old 05-01-2022, 03:08 PM
Since the rear bumper will be painted body color, we spent an entire day body working it and getting it fitted for the final time.
Greg
The Following 4 Users Say Thank You to garickman For This Useful Post:
214Chevy (05-01-2022), camcojb (05-01-2022), Goosesdad (05-23-2022), waynieZ (05-22-2022)
