Old 08-12-2021, 02:59 AM
69C40Hx 69C40Hx is offline
why mess with Tick when McLeod makes the entire kit with everything you need for your car?
Old 08-15-2021, 05:47 PM
slofut slofut is offline
71 corvette t56 here, should be similar but I wanted to stay as gm as possible. Tick stage 2 rebuild with cryo treatment, used tick throwout bearing shims, 87 gm truck master, Ls7 LUK clutch and slave. Clutch is so fine! Easy pressure but great feel, even the dyno guy commented on it. Stock 04 gto motor. 355hp on the dyno.
The Following 2 Users Say Thank You to slofut For This Useful Post:
billohio (08-16-2021), camcojb (08-15-2021)
Old 09-03-2021, 12:27 PM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
All you will need is the firewall bracket from DSE or similar.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 09-04-2021, 06:51 AM
First I have a brand new DSE bracket you can have it for 25 bucks. I only used it for Moc up.
that said ... i used this.. https://www.summitracing.com/parts/HLY-319-200
It worked flawlessly and without the problems you see in reviews about the Mc cloyd (see youtube for one example)
https://www.pro-touring.com/threads/...g-for-feedback
Footnote.. if you going to do this mod I highly recommend you mocking it all up with the petals and bracket out of the car.. get all your geometry set.. then weld it all up.. (bracket to firewall and mounting tab on clutch petal)
The Following 2 Users Say Thank You to XLexusTech For This Useful Post:
billohio (09-08-2021), camcojb (09-04-2021)
Old 09-11-2021, 09:25 AM
paulk68 paulk68 is offline
did this bolt to your DSE firewall bracket or did you remove that completely?
Old 09-11-2021, 08:53 PM
yes it did.
Old 06-12-2022, 03:57 PM
Hi Just wondering if you used the supplied u bolt to secure the clutch master. looks like i need to open up the DSE fire wall bracket holes to fit the size of the u bolt. aslo does it just go through the clutch master then the dse bracket then firewall and bolt on the inside of the cabin? If you happen to have any pictures i would love to see. thanks
