Old 07-08-2021, 04:16 PM
I had the same idea as Don, it works great for F body. If you have room.
The Following User Says Thank You to waynieZ For This Useful Post:
camcojb (07-08-2021)
  #242
Old 07-08-2021, 06:26 PM
Che70velle's Avatar
Jody, I’ve been following the build almost daily, and after seeing the wiper delima, I had to run out to the shop tonight and take some pics of mine. These are non-hidden wipers, and hide pretty good with a standard 2” cowl. If your going the flat hood route, it might be a little different, but honestly it isn’t like the wipers rest half-way up the glass. My parts car had the hidden wiper setup on it, and honestly I like the standard setup better. Just looks more 70’s to me I guess.
Thanks Dad!!
The Following 4 Users Say Thank You to Che70velle For This Useful Post:
camcojb (07-08-2021), fleet (07-09-2021), Roscoe03 (07-08-2021), waynieZ (07-08-2021)
  #243
Old 07-08-2021, 06:31 PM
camcojb camcojb is online now
I agree, looks great Scott.
Old 07-08-2021, 07:11 PM
I think you'll be fine just leaving the wipers off until they're actually needed if you go that route. I'm sure you can find some sort of cap to cover the drive studs if necessary to make it cleaner when the arms are removed.
  #245
Old 07-09-2021, 02:48 PM
Blown353 Blown353 is offline
I agree the non-recessed wipers hide much better on a 70-72 with a cowl hood as the hood and fenderline is taller than a 68-69. On a 68-69, non-recessed wipers stick way up there above the hoodline.
I'm also for the idea of putting on whatever wiper motors you want, but wrapping up the arms and blades and keeping them in the trunk until you need them.
Depending on what your car has now though you may need new wiper arms and linkage, the arms and linkage are different between recessed park and non-recessed park. Recessed park wipers will have a smaller secondary link on the driver's side wiper arm, non-recessed park wipers are single arms on both the driver and passenger side wipers. The linkage inside the cowl is a bit different too.
1969 Chevelle
Old 08-18-2021, 06:36 AM
clill's Avatar
clill clill is offline
Been over a month since last update !!!!!!!!!!!!!!!
Old 08-18-2021, 10:46 AM
And it's been over a month since I've received a part... The intercooler is finally done and shipped. Plan is to fit that and mock up the lines and then pull the body off for Jim to knock the dents out (no paint). In the meantime I'll strip the chassis and get it powdercoated, re-assemble everything for a final time, get the metal lines welded and coated, and wait for the body to come back.
The plan is to put the car together sealed and primed and tear down later for paint. I'm still missing some key items though; waited a year on a Centerforce DYAD and gave up. Fortunately McLeod is bailing me out with one of their RXT twin disc clutch setups. Still waiting for the fuel tank (6 months) after waiting several months from a different supplier. There are several other things that are still months out at best. This is NOT the time to try to build a car, getting parts is very tough.
The Following 4 Users Say Thank You to camcojb For This Useful Post:
fleet (08-22-2021), kwhizz (08-18-2021), syborg tt (09-22-2021), waynieZ (08-18-2021)
  #248
Old 08-21-2021, 04:37 PM
and it fits...
The Following 7 Users Say Thank You to camcojb For This Useful Post:
dhutton (08-21-2021), fleet (08-22-2021), Goosesdad (08-23-2021), kwhizz (08-22-2021), Roscoe03 (08-22-2021), Spiffav8 (08-27-2021), syborg tt (09-01-2021)
  #249
Old 08-21-2021, 05:15 PM
and it fits...
Pretty
camcojb (08-21-2021)
  #250
Old 08-22-2021, 12:01 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
and it fits...
Niiiiiccee!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
camcojb (09-08-2021)
Tags
70 chevelle, aeromotive, american powertrain, amsoil, baer brakes, borgeson, clayton machine, currie, dakota digital, eddie motorsports, forgeline, holley performance, hydratech, ididit, lateral-g, lokar, magnaflow, mcleod racing, mighty mouse solutions, modo innovations, morris classic concepts, painless performance, protouring, restomodair, roadster shop, rock valley antique auto parts, ron davis, texas speed, thermotec, tmi products, vintage air
