Old 09-16-2021, 03:41 PM
vet57air's Avatar
vet57air vet57air is offline
So I found another pump out of a 2000 vette and pulled the valve. It was pretty much identical my original. The small hole above the "O" ring did not go all the way through also. All three valves screw into the newest pump. Can't figure why the summit unit won't go all the way in my pump. Drilled out my original valve and reinstalled. We will see if any difference.
The Following User Says Thank You to vet57air For This Useful Post:
zz430droptop67rs (09-16-2021)
Old 09-27-2021, 09:47 AM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
Any updates?
Old 10-07-2021, 05:42 AM
UMI Tech's Avatar
UMI Tech UMI Tech is offline
For flow rate and valving questions I've always had good luck with Turn One's tech advice.
The Following User Says Thank You to UMI Tech For This Useful Post:
camcojb (10-07-2021)
Old 03-24-2022, 04:26 PM
vet57air's Avatar
Originally Posted by zz430droptop67rs View Post
Any updates?
Getting warmer and the roads are a little cleaner, so took out the Cgt for a drive. No issues at first, but once warmed up when not moving I could not turn the wheel. So worse than before.
zz430droptop67rs (03-24-2022)
Old 03-25-2022, 02:36 PM
vet57air's Avatar
Have chatted with Jeff from Turn one steering. He has given me a lot of good info. He guesses that the pump is toast. Mine is the non-oem GM type 2 pump that Drive Junky supplied with the rest of the drive system. Tried to go to Drive Junky's web site today and it says "account suspended"?
Old 03-29-2022, 08:47 AM
vet57air's Avatar
Drive Junky web site is back up and I have conversed with Zach by email.
Old 03-30-2022, 07:03 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Hope you'll follow up and let us know what happened.
These kinds of gremlins always pop up and your experience with it is of huge value to the community.
Jeff-
The Following User Says Thank You to Ketzer For This Useful Post:
camcojb (04-04-2022)
Old 04-04-2022, 08:11 AM
67-ls1 67-ls1 is offline
Following…
1966 Chevelle with 217 ci, 4 cam V6, 6 speed auto, full Hotchkis suspension, Wilwood discs all around. Built for smooth, quiet handling and max MPG.
