Old 10-09-2021, 09:05 AM
syborg tt's Avatar
Default It was late but I went out to the Garage anyway. (06-12-21 )
I didn't have much time tonight but I decided to go out to the garage.
I decided to run the GPS sensor for the Holley dash since it is a simple project.
For now I just mounted the wires near the back of the dash.
Well, I know I should have went out to the garage as I ended up being out there way to long.
I started running wires from the ECU to the brake light switch (still not connected) and the ignition hot wires over to the fuse panel.
I also started running the Additional output wires to the P-Side kick panel
Made another hole in the car.
Labeled all of the wires with Heat Shrink wrap.
Started planning the DBW routing.
More Instruction that I need to sit down and read.
Pictures for reference.
Wires
Plugging it all in.
I recently started my bucket of shame
Let's not forget the vacuum line...ugh
Just in case you all were interested in the part #'s of the heat shrink tube I am using.
Calling it even thought I was only going to be out in the garage for a short period of time I stayed a little longer and got a bunch done.
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
camcojb (10-09-2021), fleet (10-09-2021), jarhead (10-09-2021), Spiffav8 (10-10-2021)
Old 10-09-2021, 09:33 AM
camcojb camcojb is online now
If you only have a bucket you're doing great, mine would be a barrel of shame lol.
The Following 3 Users Say Thank You to camcojb For This Useful Post:
Sonar Chief (10-18-2021), Spiffav8 (10-10-2021), syborg tt (10-09-2021)
Old 10-09-2021, 02:00 PM
syborg tt's Avatar
Don’t worry there was plenty more in the past.
marty-mj
camcojb (10-10-2021)
Old 10-09-2021, 09:56 PM
warhawkchevelle warhawkchevelle is offline
This is an awesome project to follow.
All the attention to details, minor and bigger is impressive.
Plus its a beautiful car!
The Following User Says Thank You to warhawkchevelle For This Useful Post:
syborg tt (10-10-2021)
Old 10-10-2021, 10:11 AM
syborg tt's Avatar
Thank you so much.
marty-mj
Old 10-10-2021, 09:25 PM
syborg tt's Avatar
Default More parts and more holes (06-13-21)
The pile of parts in the attic is getting smaller.
So I need to get this giant plug through the firewall and I have no desire to make a big hole in the firewall.
Yes, Once again I called Andrew to ask him how to take this plug apart.
Mike and I trying to figure out the best location for the two holes.
Big Drill, Big Hole and lot's of torque just because I needed a bigger bit.
Thank god I missed the harness
He is finally getting comfortable in the garage.
Side note we also work on 4Runners
The holes have been plugged.
Mike taking the plug apart
marty-mj
fleet (10-18-2021)
Old 10-11-2021, 05:41 AM
jarhead's Avatar
jarhead jarhead is online now
That Pup is the cutest!
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
syborg tt (10-11-2021)
Old 10-18-2021, 05:38 PM
Sonar Chief's Avatar
Looking great ... note: Blair makes Holecutter kits that are way more precise than a big ol drill bit, we use them at the restoration shop and they save a ton of time, just saying!!!!
The Following User Says Thank You to Sonar Chief For This Useful Post:
syborg tt (10-27-2021)
