Old 01-10-2022, 03:48 PM
Bad Bowtie Bad Bowtie is offline
Originally Posted by 572Camaro View Post
BB,
Don’t change a thing!
3/8” diameter will work fine.
I didn’t ask Gordon about larger diameter.., my bad.
I chose 5/16” because:
1. Mark and Gordon both indicated it was big enough.
2. I got really tight clearance everywhere and I can get tighter bends in my tubing.
3. Frankly, it looks better..,
BRAG: we won most outstanding engine bay at Detroit Autorama a couple years back.
ADVICE: if you run “hard” engine mounts, and if you run hard lines, no need for a flex hose in between.
BOTTOM LINE: You are fine.., just shut the hood and drive it like you stole it!
My stainless lines were a little bit of a chore too. This is from when I got the project started last year. I then ran the tubing from the starter tucking next to the pan as GM did forward up near the radiator. I used PTFE braided lines for the connections. I'm thinking with the trans cooler having -6 AN I should be good
BB
The Following 3 Users Say Thank You to Bad Bowtie For This Useful Post:
572Camaro (01-11-2022), camcojb (01-10-2022), Gmachine1911 (01-10-2022)
