Old 01-05-2022, 12:11 PM
andrewb70's Avatar
I wouldn't hang the sensor off the rail or anywhere on the engine. The vibrations will kill even the highest quality sensors eventually. My Holley sensor lasted on the rail for about 15K miles.
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (01-05-2022), Ketzer (01-05-2022), syborg tt (01-09-2022)
  #1702
Old 01-09-2022, 07:49 PM
syborg tt's Avatar
Default This may seem excessive but WTH I am doing it anyway (10-16-21)
As you all know I have issue's and because of that I gently removed all of the screws from the Notchhead clamps so I could put a
little grease & paint in them to hopefully prevent the holes from rusting.
I will also be removing all of the blue tape. Yea Me !!!
I put a very thin coat of Duplicolor paint and primer in one in all of the holes as this would be the easiest way to apply paint without getting it everywhere.
On a side note the Billet Battery Tray Wilson Muscle Car designed makes a very nice parts tray.
All of the Blue Tape has finally been removed from the subframe.
marty-mj
camcojb (01-09-2022), fleet (01-11-2022)
  #1703
Old 01-10-2022, 08:11 PM
syborg tt's Avatar
Default Holley Sniper Injector Harness Cleanup ( 10-16-21 )
I have one of the early Holley Injector harness that has a white tag for the injector number which is just ugly so I rolled each label and
then wrapped in clear electrical tape. These will be hidden under the Tech-Flex wrap.
I printed new labels that I applied to each injector plug. However, they will most likely fall off but it will just make it easier to put them
where they belong when I plug everything in for the last time.
I also redid the wire wrap so the wires would be hidden from view.
marty-mj
fleet (01-11-2022)
  #1704
Old 01-10-2022, 08:38 PM
syborg tt's Avatar
Default Optima Mock Up Battery ( 10-21-21 )
I knew these existed and when I asked the Optima guys at Columbus Good-Guys last year of course they said they would call me
back. However, no one ever called so I took it upon myself to find an empty Optima Battery Case.
Now that I have one and I can prove that they actually exist.
marty-mj
Old 01-11-2022, 12:05 PM
syborg tt's Avatar
Default Trans Coolant Line DEI Heat Sleeve ( 10-21-21 )
Hopefully this will be the last time I have to move these lines.
I installed the DEI Heat Sleeve over the soft lines as they are near the Edelbrock Shorty Header.
So while I was installing the hose I felt something on my legs and low and behold my new puppy decided he wanted to take a nap on my legs.
marty-mj
fleet (01-11-2022)
  #1706
Old 01-11-2022, 12:15 PM
syborg tt's Avatar
Default Final Fuel Line Connection To Fuel Rail ( 10-24-21 )
Having to make the last cut on the fuel line was fun and yes I was worried about cutting it to short.
This was the final line which goes under the throttle body.
I also want to make sure that the line wouldn't rub on anything.
marty-mj
camcojb (01-11-2022), fleet (01-11-2022)
  #1707
Old 01-11-2022, 01:58 PM
syborg tt's Avatar
Default The last of the wiring under the Sniper Intake ( 10-24-21 )
Making sure the last bit of wiring under the intake manifold will be safe from harm.
If you look closely you can see the fitting that Holley supplied are useless.
When we build in the intake tube we are going to weld tabs under the tube so we can zip tie the MAF wire harness under the tube.
I also ran the Drive By Wire harness under the manifold.
All of the wiring has been heat wrapped going to the starter.
marty-mj
Old 01-11-2022, 02:13 PM
Panteracer's Avatar
Default 2nd Chance Camaro
All the wiring on my new Gt-1 car has plastic
dip over all the final connections to keep things together
and my guess prevent corrosion. Never have seen that before
Every bolt is very
hard to break loose on this car... very impressed whoever
put it together. Like dirt bikes race cars have bolts falling
off them all the time
Love the way you keep your wiring all run cleanly
Bob
The Following User Says Thank You to Panteracer For This Useful Post:
syborg tt (01-12-2022)
  #1709
Old 01-11-2022, 05:51 PM
Nice work, Marty! This is going to be really clean under the hood.
  #1710
Old 01-12-2022, 08:07 AM
Gmachine1911's Avatar
Looks really good, Marty, you’re attention to detail is amazing! I was admiring what I suspect to be your transmission cooler lines running along the top of the subframe…I’ve gotta decide what type (hardline or flexible) and where to run the lines for my Nova project and was wondering if you used PTFE lines or something else?
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
The Following User Says Thank You to Gmachine1911 For This Useful Post:
