Old 01-15-2022, 05:28 PM
syborg tt's Avatar
Default Optima Batter Charger Plug ( 11-09-21 )
Since I keep the car on the optima charger when it is parked in the garage I decided to mock up the wire and see if I could hide it when it's not in use.
I can easily tuck it in the frame rail when not in use.
marty-mj
camcojb (01-15-2022), Ricochet (01-15-2022)
Old 01-15-2022, 06:14 PM
syborg tt's Avatar
Default Trunk Grounds Wires ( 11-12-22 )
Today I will be working on all of the various ground wires.
My goal is to make then looks nice and I even have some company in the garage today.
Ground wire from the block to the frame
Wires running back to the battery ( I think I have a cool idea and I hope to share it soon )
Securing the ground wire to the motor mount bolt.
I am finally connecting the wires from the relay to my gas tank.
I also purchased this bad ass headlight switch from a gentleman on Facebook. I am going to have it anodized
black so it blends in with the Covan dash insert.
I have been looking for Intake Tube idea's and I think I found one that I love.
marty-mj
camcojb (01-16-2022)
Old 01-15-2022, 07:27 PM
syborg tt's Avatar
Default Fuel Line Routing ( 11-14-21 )
Another reminder while I am here to powder coat the spring pocket and the lower arms.
The fuel lines runs right over the spring pocket and I am going to trim a little bit of it off to protect the fuel line.
I started slowly removing just a little bit.
Then I took just a little more off.
Out comes them death wheel.
A little clean up.
All better now and I am still going to run the line through DEI ExoSleeve.
marty-mj
Old 01-15-2022, 07:57 PM
syborg tt's Avatar
Default Kore3 FlexKORE Brake Line ( 11-14-21 )
I am finally installing the FlexKore brake lines.
Old lines are coming out.
marty-mj
fleetus macmullitz (01-16-2022)
