Old 01-20-2022, 07:20 PM
syborg tt's Avatar
Default Yes, I know this is overkill ( 11-14-21 )
I think I am going to rename this car to Project Overkill
Once again I am taking the passenger side header off so I can get to the wiring at the starter.
So I dropped the lock washer of course my floor is speckled gray so it blended right in.
Eventually I laid on the ground with the flashlight so I could find the freaking thing.
marty-mj
Old 01-20-2022, 07:32 PM
syborg tt's Avatar
Default Wiring toolbox ( 11-14-21 )
So the other day I was looking at all of the tools I have collected for wiring this car and I thought I would share pictures of my tool box that is completed dedicated to wiring. So when the car is done it will be going back to my warehouse.
marty-mj
Old 01-20-2022, 07:52 PM
syborg tt's Avatar
Default Fuel Line Routing & DEI Heat Protection ( 11-20-21 )
I need to widen this rectangular hole so the fuel line can pass through this opening safely.
I installed the DEI Heat shield and EXO-Sleeve.
I am still trying to figure out if I am going to secure the line to the firewall or just let it hang from the fuel rail. Which doesn't sound good as I type this.
This is the final AN fitting that I need to finish the fuel line.
marty-mj
Old 01-20-2022, 08:12 PM
syborg tt's Avatar
Default ARP Battery Bolts ( 11-25-21 )
I am not a fan of battery bolts and I really like ARP bolts. Since Rad Rides uses them on their builds I might as well use them on my car.
Apparently the bolt got a little warm.
I ran the bolt all the way in to make sure it wasn't to long. Eventually I will order the correct bolt.
marty-mj
Old 01-21-2022, 05:19 AM
fleet's Avatar
fleet fleet is offline
“Project Overkill”?
…or
The Following User Says Thank You to fleet For This Useful Post:
syborg tt (01-21-2022)
Old 01-21-2022, 09:38 AM
syborg tt's Avatar
Skip thank you for making me laugh
“Project Overkill”?
…or
marty-mj
fleet (01-21-2022)
Old 01-21-2022, 12:33 PM
fleet's Avatar
MJ,
You’re welcome…cuz anyone who does this to himself building a car deserves a laff!
Old 01-23-2022, 09:26 AM
srode1 srode1 is offline
And that is why I didn't put much flake down over my floor when I epoxied it, too hard to find dropped parts.
The Following User Says Thank You to srode1 For This Useful Post:
syborg tt (01-23-2022)
