Old 02-14-2022, 05:22 PM
syborg tt's Avatar
Looks really nice and I am looking forward to more updates.
marty-mj
Old 03-26-2022, 05:54 PM
Mikael A Mikael A is offline
Well the ups guy showed up so a little bit of plumbing,electrical being done and some other cool parts.
Lots more will happen now that spring is coming.
Mike a
The Following 5 Users Say Thank You to Mikael A For This Useful Post:
camcojb (03-27-2022), jarhead (03-27-2022), Roscoe03 (03-26-2022), Spiffav8 (03-28-2022), syborg tt (03-27-2022)
  #103
Old 03-27-2022, 07:43 AM
syborg tt's Avatar
Holley 370amp Alternator.
Why you need so much juice as this kind of power is way above my head !!!!
marty-mj
Old 03-27-2022, 09:32 AM
It’s only 200 amps at idle and helps with any voltage drops since my battery is in the trunk.
Probably way overkill but i run them on everything I have and never had a problem.
Mike a
The Following 3 Users Say Thank You to Mikael A For This Useful Post:
camcojb (03-27-2022), Spiffav8 (03-28-2022), syborg tt (03-28-2022)
  #105
Old 03-27-2022, 11:08 AM
Blast from the past,this was 15 years ago
Mike a
Roscoe03 (06-04-2022), Spiffav8 (03-28-2022), syborg tt (03-28-2022)
  #106
Old 03-31-2022, 09:16 PM
Really clean looking setup. Any concerns with the hardline between the catch can and valve covers as the motor moves around?
Old 04-01-2022, 02:36 PM
I’m actually working on a bracket right now that mounts to the back of the head and holds the catch can in place.
Mike a
Old 04-02-2022, 12:25 PM
This is the bracket that holds the catch can,I will probably have this done in black when i get the ict brackets done.
Mike a
The Following 6 Users Say Thank You to Mikael A For This Useful Post:
130fe (04-05-2022), camcojb (04-02-2022), Goosesdad (04-05-2022), Roscoe03 (04-03-2022), syborg tt (04-04-2022), waynieZ (05-24-2022)
  #109
Old 04-02-2022, 05:14 PM
Nice work!
Mikael A (04-02-2022)
  #110
Old 04-03-2022, 03:24 PM
So i was not happy with the big bend before the valve cover,I ordered a 90 degree fitting instead and ended up redoing the whole thing.
Also my new fuel tank showed up and cant be happier with RCI,fully custom size,baffles,efi ready,sending unit and they made me a filler neck.
Mike a
camcojb (04-03-2022), Roscoe03 (06-04-2022), syborg tt (04-04-2022)
