Old 07-02-2022, 04:49 PM
Number1 Number1 is offline
Okay. Thanks guys.
Old 07-15-2022, 09:59 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Sorry for the lack of updates. Ok this is going to be long since its been a while since I've updated this. I'm just gonna touch on everything kinda quick since the pics are worth a thousand words.
Looks like last update I had mounted the ABS. After that I built a washer reservoir and used it to mount the supercharger cooler pump.
I fabricated a fuel fill pipe to connect the filler to the tank thats behind the drivers seat.
Then I moved onto the frame work for the rear package tray delete panel/waterfall, sanded everything down and shot it in black epoxy.
Which led to the waterfall being fabricated out of .040 aluminum, The plan is for this to be carped on the lower section and leather on the upper section with a 12" sub in the middle. Also a start of the rear side panels.
A quick little fuse bank holder next to the battery to hold the Mega fuses that power my Infinity Box system.
Some body and paint work on the firewall to get that moving in the right direction as well as the supercharger lid and cover. I'm a big fan of this red and black color combo that will be against a matte black engine bay and the metallic blue the car will be.
The engine has been mostly assembled and I welded AN fittings to the valve covers and bigger fittings on the breather tank.
Around this time I started to work on the side skirts and get them ready to make molds from.
I also took the car to a local car show. Turns out I wasn't the only trailed car there.
Instagram- camaroaj
The Following 6 Users Say Thank You to CamaroAJ For This Useful Post:
89 RS (05-03-2024), andrewb70 (08-02-2022), camcojb (07-15-2022), dhutton (07-16-2022), Goosesdad (07-27-2022), Roscoe03 (07-16-2022)
Old 07-15-2022, 10:01 PM
CamaroAJ's Avatar
I've been messing with the wider body up front to clear the wheels. I used foam as a base then fiberglass to get a little more solid and shaped it with body filler. After all this is final I'll prime and paint it, wet sand, then buff to a high shine so I can make a mold off it then make a carbon fiber panel to replace everything with.
I've also finished up my C6 door latch swap and trimmed the under side of the hood so I could get to the secondary latch when I pop the hood. That will all be repaired with carbon and body worked so it looks like it came that way.
I mounted up the heat exchanger, oil cooler, and power steering cooler. Unless I had a stock one side by side you'd never be able to tell all the work I did on the header panel support to keep it looking factory while clearing the tilted forward radiator, mounting the power steering cooler to it, and raising up the mount to fit the Porsche hood latch. Oh, and dimple die holes for some weight savings.
Some modern magic with this rev match module so I don't have to heel/toe all the time when down shifting. Perfect spot in the center console for it and out of site.
The last of the update brings us to some grille block off panels. Since the goal is to keep as much needless air as I can from going into the engine bay I made up these block off panels for the grille. I made them out of .040 aluminum to the size of the heat exchanger and oil cooler and duct them to the coolers. The center I left wide enough to blow onto the power steering cooler.
Instagram- camaroaj
The Following 10 Users Say Thank You to CamaroAJ For This Useful Post:
214Chevy (07-18-2022), camcojb (07-15-2022), dhutton (07-16-2022), fleet (07-17-2022), Goosesdad (07-27-2022), Ketzer (07-21-2022), Mikael A (07-17-2022), Number1 (07-17-2022), waynieZ (08-03-2022), WSSix (07-17-2022)
Old 07-15-2022, 10:17 PM
camcojb camcojb is online now
Very nice work!!!
Old 07-17-2022, 09:52 AM
Goosesdad's Avatar
Awesome AJ!!!
Have a great day!
John
My Build Thread:
Old 07-17-2022, 12:05 PM
Mikael A Mikael A is offline
Looks great
Mike a
Old 07-17-2022, 04:28 PM
Welcome back. Great update as usual, I want those corvette door openers on my car too. Did you decide on what side mirrors that you were using?
Old 07-24-2022, 06:04 PM
Cramer4918's Avatar
Your skills are amazing AJ! I can appreciate all the work you are putting into this KILLER ride!
-Matt-
'61 Biscayne ~ AKA BISKWIK
Old 04-26-2024, 03:02 PM
dhutton dhutton is offline
Saw this
https://www.instagram.com/reel/C6KnG...RlODBiNWFlZA==
The Following 2 Users Say Thank You to dhutton For This Useful Post:
ADY (04-29-2024), camcojb (04-26-2024)
Old 09-19-2024, 08:42 PM
CamaroAJ's Avatar
Long overdue update. I've kinda lost motivation to work on the car, but I'm still trying to get things progressing forward. There is some small stuff here and there thats not really important, so I'll skip some stuff and hit the major things. It looks like I left off with the fenders and front end close outs. Well, the fenders still aren't done. Long story short, I'm waiting on a guy to model them in CAD and then another guy to 3D print them for me as I don't have a big enough printer. More on that to come.
Lets start with the exhaust. I had a set of 2" headers from a well known company. Turns out they wern't even close to fitting even though they were for a Corvette chassis. I cut them up and turned them into a set of Tri-Y headers. I ran full 3" to the back with 2 X-pipes and a set of cut outs. The muffler is a Holley part that a buddy that worked for their technical team was able to get me. Its an internal crossover muffler used on the 6th gen Camaro systems they sell. The cutouts skip the muffler at the back similar to C6, and C7 Corvettes as well as 6th gen Camaros and CTS-V's work. Its all vacuum operated and I'll have a controller that opens and closes them based on throttle % and RPM as well as a manual override for full open and closed. I used Sendcutsend to laser cut out exhaust tags with my cars name and logo that also reinforce the X-pipe. Also as you can see, the tail panel has been cut out for the future home of the exhaust tips.
**Its too big of pain in the ass to put them in order, sorry**
Exhaust 98% done I started roughing in the defuser in foam. This will eventually be made out of carbon fiber.
The bottom of the hood is also 95% done
I cut up some very nice and expensive carbon fiber A-pillar moldings. After foaming and shaping to fit my dash everything was fiberglassed. The foam was cut out from the back side and then everything was body worked and primed. I don't know if I'll warp them in leather or paint them yet.
At this point the shop I was working for moved into a new shop. With that we got our mill and lathe running. Knowing I wasn't going to stay working there for too much longer I knocked out as much machine work as I had/needed. I made bushings for the core support, lift pucks, cable adapters for the doors. The throttle pedal to match the rest of the Corvette pedals, but without the crappy wobble that they are known for. Most importantly I machined a ton of stainless bolts and whats a cool looking bolt without an awesome moto inspired aluminum washer? 1/4", 5/16", and 3/8" along with some metric so the engine stuff matches. I also machined threaded bungs for tow hooks for track days that are easily removable.
I also finished my engine and mounted the mirrors.
Oh, and the supercharger received some CNC race porting just to keep things spicy.
The mock up lower radiator mounts I finally got around to making out of aluminum and getting them finished.
At this point I went to work for another shop that supports my ideas instead of telling me that most places don't do what I have in mind. Thats 3D printing. I spent a bunch of money and bought a new laptop, 3D printer setup, 3D scanner, and CAD software and then took the youtube crash corses on how to do it all. The second car part I made was a mount for my BMW soft close trunk latch, which I retro fitted into my car.
Instagram- camaroaj
The Following 3 Users Say Thank You to CamaroAJ For This Useful Post:
camcojb (09-20-2024), Goosesdad (09-20-2024), syborg tt (11-26-2024)
