Old 07-03-2022, 01:28 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Making awesome progress Greg, thanks for sharing all your work. I sent you a PM the other day, did you just put the trans tunnel in as high as you could reasonably get it? I'm trying to decide if I want to gamble and put mine in before I get my T56 Magnum transmission.
Erik
69 Camaro
Old 07-03-2022, 01:42 PM
garickman garickman is offline
Originally Posted by ErikLS2 View Post
Making awesome progress Greg, thanks for sharing all your work. Did you just put the trans tunnel in as high as you could reasonably get it? I'm trying to decide if I want to gamble and put mine in before I get my T56 Magnum transmission.
Thanks! I did not even have my transmission when I installed the tunnel. Fortunately, I live about 5 miles from Speedtech. I am there all the time so it is easy for me to take pictures and measurements when I need them and pick the brain of their lead fabricator. It is pretty much at the highest point, but if I did not have access to Speedtech, I think I would have waited to get the trans mocked up first.
Greg
The Following User Says Thank You to garickman For This Useful Post:
ErikLS2 (07-03-2022)
  #173
Old 07-03-2022, 02:28 PM
ErikLS2's Avatar
I checked with them, they just said the front is based on installed transmission height. By any chance is your car in a state that you could get a measurement from the bottom of the dash to the top of the tunnel? I move at a snail's pace, so no rush. Thanks for the help!!
Erik
69 Camaro
Old 07-04-2022, 02:45 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
C'mon Greg ... I'm dying to see some colour !!
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 07-04-2022, 07:42 AM
I can do that but you will have to give me a few weeks. The interior is masked off and sealed so I can't get inside.
Greg
ErikLS2 (07-05-2022)
  #176
Old 07-04-2022, 07:57 AM
Steve
You and me both. Unfortunately, my enemies are time, space and weather. I am limited on the time my body and paint guy can work on it, I usually have to move a bunch of stuff out of my garage to have room to work and then I have to move it all back in at the end of the day, and here in Southern Utah we have had 10 straight days above 100 degrees and it only gets worse from here. In the next few weeks we will start to see our annual 107-112 degree temps.
Here is a few pics of what my Mondays usually consist of after working on the car all weekend. I thought the bondo dust was bad enough but damn that poly primer dust.
Greg
The Following 6 Users Say Thank You to garickman For This Useful Post:
camcojb (07-04-2022), Goosesdad (07-07-2022), Mikael A (07-04-2022), Roscoe03 (07-15-2022), Spiffav8 (07-05-2022), waynieZ (07-06-2022)
  #177
Old 07-05-2022, 10:41 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Amazing that something that looks amazing out of such a mess.
Worth it though
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
garickman (07-06-2022)
  #178
Old 07-15-2022, 06:55 PM
Cramer4918's Avatar
Little progress is still progress! It will all be worth it in the end. Hopefully weather will cooperate for you soon.
The Following User Says Thank You to Cramer4918 For This Useful Post:
garickman (07-19-2022)
  #179
Old 07-31-2022, 04:43 PM
So the only thing left to do for this round is to block the tail panel, back of the rear spoiler and the hood. The car is fully assembled with all bolts, shims and latches in place. We should be done with the blocking in the next couple of weeks and then we will blow the car apart and spray everything with CRE. Once the CRE is layed down we will do a final blocking on all parts and get ready for paint. I am locked into white with the black hockey stripe just as original. I do like white and I figure you can't go wrong with an original factory color. Here is a sneak peak of what things are looking like.
Greg
camcojb (07-31-2022), cpd004 (08-05-2022), JB400 (08-01-2022), Mikael A (08-04-2022), Ricochet (07-31-2022), waynieZ (08-03-2022)
  #180
Old 08-02-2022, 04:11 PM
Spiffav8's Avatar
Lateral-g Moderator
This is looking SO good. Looking forward to some color!!
Curtis
The Following 2 Users Say Thank You to Spiffav8 For This Useful Post:
garickman (08-03-2022), waynieZ (08-03-2022)
