  #33
Old 09-27-2022, 10:41 AM
gnx7's Avatar
gnx7 gnx7 is offline
Summer is finally over and my swimming pool biz is slowing down a bit. Finally had some time to get the car running. Fixed a leaky fuel tank (pinhole leak), nut/bolted the car, cut the wastegate piping flush to the bottom of the car for more ground clearance. My buddy Mike quickly wrote a basic tune and it literally fired up on the 1st attempt as you can see!
The engine may have a vacuum leak as it doesn't want to idle below 1500rpm. Still tinkering a bit more... next week it should go off to Hill's Rod & Custom local to me for new axle seals, longer rod in the brake master cylinder (not enough stroke to bleed the brakes), corner weight and alignment. Kurt Hill races a wild K5 Blazer dropped on top of a C5 chassis. He will also shake down the car to see what else is potentially needed to make it safe.
Pretty excited to FINALLY hear it run.
exhaust note:
The Following 4 Users Say Thank You to gnx7 For This Useful Post:
130fe (09-29-2022), Che70velle (09-28-2022), Roscoe03 (09-27-2022), waynieZ (10-01-2022)
