Old 09-26-2022, 02:59 PM
Cramer4918's Avatar
Thank you so much and my goal has been to make the car easy to service and hopefully reliable.
The Vintage Air install was fun and if you need to borrow the AC line crimper I loan it out for a small $25.00 donation to the charity I work with and the good part is you get a tax donation.
That is an awesome and great idea, Marty! I may have to take you up in your offer when I get back in mine.
I’ve been looking at the Rivnut tool at Harbor Freight. That would definitely prove useful for my shifter and Holley Terminator mounts.
Seeing your updates is great motivation!
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
syborg tt (09-26-2022)
  #1882
Old 09-26-2022, 04:07 PM
syborg tt's Avatar
Thank you Matt and the Rivnut tool from Harbor Freight works good not great. But if you are only doing a few then who cares.
On a side note I also rent out the Fender Roller and Back Spacing tool and all of the money get's donated to the Charity.
marty-mj
camcojb (09-26-2022), Cramer4918 (09-30-2022)
  #1883
Old 09-27-2022, 10:52 AM
syborg tt's Avatar
Default Slip Yolk Travel (( 07-16-22 ) Got a Question...Need Advice
Back out in the garage and back at it.
The guys at Pro-Tek Powder Coating did an incredible job on the Yolk. However he may have put a little bit to much powder coating on the shaft.
So I have question how much inward travel should I expect ??
marty-mj
fleetus macmullitz (09-28-2022)
  #1884
Old 09-27-2022, 11:09 AM
camcojb camcojb is online now
So how far in does it go until it bottoms out? If it bottoms out before hitting the powdercoated section you're good. Dennys Driveshafts wants 3/4" for forward movement, so if the driveshaft is installed and car at ride height, if the powdercoated area is 1" or more back from the seal you're good.
Of course you can always sand some coating off to give yourself more room if needed. Tape off the clean part of the yoke and touch up the end of the powdercoating with matching paint, nobody will notice.
How much slip travel should I have?
In most applications the minimum is 3/4 inch and more than 1 inch is not necessary. This is measured with the rear suspension supported on safety stands or with the rear end on the ground.
https://www.dennysdriveshaft.com/fre....html#faq_id10
syborg tt (09-27-2022)
  #1885
Old 09-27-2022, 01:04 PM
sleepertime's Avatar
sleepertime sleepertime is offline
Smile
Except Marty will know...
My build BRNAGN 1969 camaro SS
The Following User Says Thank You to sleepertime For This Useful Post:
  #1886
Old 09-27-2022, 02:06 PM
syborg tt's Avatar
Thank You and I was hoping that is what you would say. It looks like I am going to remove another 3/8" of the powder coating which will give me 1.25" of inward travel.
marty-mj
Old 09-27-2022, 03:27 PM
syborg tt's Avatar
Default Torque Convertor Shim (( 07-16-22 ))
Have I ever mention how much I love shimming a Torque Convertor....
Once again the passenger side header needs to come off.
Note... Don't forget to ZipTie the starter wires together.
Starter back off once again.
New ARP bolts
Here we go
I needed to add tape to my collapsible magnet magnet.
First Bolt in.
Well the tool cart is sure looking full.
In order to roll the motor over the plugs must come out.
So I don't have the pictures of me putting the last two bolts in but let's just say this job sucked !!!
Instead you get a nice picture of Remy.
Header going back in.
If you look close you will see that I forgot to zip tie the starter wires. I should have put a blue tape note on it.
I also moved the Lokar Dip Stick back one bank and it has a much better engagement with the block.
marty-mj
fleetus macmullitz (09-28-2022), Roscoe03 (10-01-2022)
  #1888
Old 09-30-2022, 09:25 AM
syborg tt's Avatar
Default Finally finishing up the Ground Wiring (( 07-17-22 ))
I am back trying to finish up the ground wiring.
I am going to remove the mock up wiring and replace it with the 6AWG wire.
I also move the Holley ground wire to the remote shut off.
The wire was a little long and the lug for the batter was just a little bit big.
marty-mj
camcojb (09-30-2022), fleetus macmullitz (09-30-2022)
  #1889
Old 09-30-2022, 01:59 PM
syborg tt's Avatar
Default Holley O2 Sensor (( 07-23-22 ))
Nice Simple project
Added Techflex wrap to the harness.
I added some copper Anti-Seize to the threads
Thanks fully all of this is hidden behind the motor.
Love what stuff you need goes on sale at your local auto parts store.
Now I can finally tighten that nut.
marty-mj
Cramer4918 (09-30-2022), fleetus macmullitz (09-30-2022)
  #1890
Old 09-30-2022, 02:13 PM
syborg tt's Avatar
Default Trans Coolant Lines Final Connections (( 07-23-22 ))
You only get one chance to cut these lines once so don't screw up.
marty-mj
fleetus macmullitz (10-01-2022)
