Old 10-13-2022, 10:45 AM
sleepertime's Avatar
sleepertime sleepertime is offline
Post Just something additional to think about.
It looks like you have done a great job crossing all your T's and dotting your I's, but I wanted to share some information about a product that I have been using on my battery terminals and all of those hard to get to electrical connections and plugs that have a tendency to get moisture on them.
https://www.corrosionx.com/collectio...30930717966432
My build BRNAGN 1969 camaro SS
The Following 3 Users Say Thank You to sleepertime For This Useful Post:
Goosesdad (10-14-2022), Jimbo1367 (10-14-2022), syborg tt (10-13-2022)
  #1922
Old 10-13-2022, 10:50 AM
DWC's Avatar
DWC DWC is offline
Hi Daniel,
I am doing this from memory and I am fairly certain I am correct that it is 3/8". On a side note I went with the Gate's hose is the hose wasn't as flimsy as the generic 3/8" hose that I had laying around.
Thanks Marty!
Daniel
Old 10-13-2022, 03:28 PM
syborg tt's Avatar
Default Lokar Dip Stick Fill Tube (( 09-18-22 ))
Today was the day I get to see if what I created works and of course the Ice Cream Oreo Cookie Sandwich just because.
Works Perfectly
Eight Quarts in and no leaks.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
fleetus macmullitz (10-13-2022), Goosesdad (10-14-2022), waynieZ (10-15-2022)
  #1924
Old 10-13-2022, 03:32 PM
syborg tt's Avatar
Default Power Steering Fill & Bleed (( 09-28-22 ))
Mike came over help me fill and bleed the power steering pump.
More notes
marty-mj
  #1925
Old 10-13-2022, 03:37 PM
syborg tt's Avatar
Default AAW Start Up Wiring confirmation (( 10-02-22 ))
Getting closer and closer.
The new battery is installed and power is being supplied for the first time in three years.
We have lights
Uhm we don't have working indicators so Mike starts hunting for the issue. Well about 5 minutes latter Mike discovers that
the steering column wasn't plugged into the body harness.
DA !!!
marty-mj
Cramer4918 (10-13-2022), fleetus macmullitz (10-13-2022)
  #1926
Old 10-13-2022, 03:51 PM
syborg tt's Avatar
Default Time to install the Upper & Lower Valance. (( 10-02-22 ))
In order to get the Upper Valance installed we need to remove the headlight buckets.
It's hard to believe these parts are actually out of the Garage Attic.
While they were off I had Larry paint the back of the parts Satin Black.
Here we go.
Sorry no pics of the lower valance going on just partly installed.
We just set the Anvil Carbon RS bumpers on the car.
The tool cart is full once again.
I am finally Officially caught up.
marty-mj
  #1927
Old 10-13-2022, 04:16 PM
Cramer4918's Avatar
Getting closer, Marty!
I am excited for you!
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following User Says Thank You to Cramer4918 For This Useful Post:
syborg tt (10-14-2022)
  #1928
Old 10-14-2022, 04:57 AM
Marty,
Your getting a lot done. That’s got to feel amazing. Are you going to be running inner wheel wells ? I couldn’t imagine getting the detailed engine compartment dirty.
The Following User Says Thank You to Jimbo1367 For This Useful Post:
  #1929
Old 10-14-2022, 07:18 AM
fleetus macmullitz's Avatar
Colonel McFly looked weary as he put the finishing touches on his $6mm Camaro…
The Following 2 Users Say Thank You to fleetus macmullitz For This Useful Post:
camcojb (10-14-2022), syborg tt (10-14-2022)
  #1930
Old 10-14-2022, 09:17 AM
syborg tt's Avatar
Thank you so much.
Originally Posted by Jimbo1367 View Post
Marty,
It sure does and yes I plan to run the inner fenders. I am keeping them off for now as it will be easier to check for leaks and find things that I missed.
LOL Skip you crack me up.
marty-mj
fleetus macmullitz (10-14-2022)
