Old 12-29-2022, 08:56 AM
Cramer4918's Avatar
I finally got out to the garage and into the attic. Unfortunately I don’t have one.
Thank you for looking, Marty. I did receive the fittings and will be moving on to completing the A/C setup once I finish the main wiring.
I have the panel made up and am in the process of mocking up the layout of the electronics and the wiring. Once I get it how I like it, I'll take it apart and fine tune the panel and paint it.
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following 3 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (12-29-2022), Goosesdad (12-29-2022), syborg tt (01-04-2023)
  #72
Old 01-12-2023, 11:23 AM
Cramer4918's Avatar
Just a tiny update…
BISKWIK got some new shoes and improved stance!
Here are the Before and After shots.
-Matt-
The Following 4 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (01-12-2023), Goosesdad (03-28-2023), Roscoe03 (01-14-2024), waynieZ (01-21-2023)
  #73
Old 01-12-2023, 01:29 PM
Che70velle's Avatar
Matt, that looks soooo much better. Well done sir.
Thanks Dad!!
Old 01-12-2023, 02:35 PM
Cramer4918's Avatar
Thank you, Scott!
Hopefully it will be moving under its own power soon.
-Matt-
Old 03-27-2023, 08:30 AM
Cramer4918's Avatar
Not much of an update. We went on vacation early February and I got pretty sick upon return to the tune of 103 fevers with meds and a total weight loss of 19 lbs in a week and a half. I was in bed for three days and wasn’t able to eat. We are guessing it was a strain of some type of Flurona. 🤷🏻*♂️ A month later and I’m up four lbs and my stamina definitely isn’t what it used to be. I’ll get back to where I was, mainly because I’m stubborn.
I did get a new radiator/ fan setup for BISKWIK though. I’ll be working on getting that mocked up with the MSD Solid State relay. More pics to come!!!
-Matt-
camcojb (03-27-2023), Goosesdad (03-28-2023), waynieZ (03-27-2023)
  #76
Old 03-28-2023, 07:02 PM
Cramer4918's Avatar
I did manage to get the fans mounted and the setup temporarily in place. I wanted to make sure there was plenty of clearance with the steering box and the accessory drive. All looks good so far! I just have to massage a couple holes on the fan shroud to get them to line up properly.
-Matt-
The Following User Says Thank You to Cramer4918 For This Useful Post:
camcojb (03-28-2023)
  #77
Old 03-28-2023, 07:06 PM
Cramer4918's Avatar
I was also able to make some progress on making panels to fill in the holes between the back seat and the trunk. I did not seal it off completely, but it is a vast improvement over what it was. The wheel wells have a healthy layer of undercoating in them, so I did not add any material to the interior.
-Matt-
The Following 2 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (03-28-2023), syborg tt (04-04-2023)
  #78
Old 03-28-2023, 07:10 PM
Cramer4918's Avatar
Once I completed that task, I employed the help of my Mini-Me and installed the seatbelts in the back. Once we got those bolted in, the backseat was put back in place. It’s a little dirty and will be cleaned, but it’s starting to look like a car inside again!!!!!
-Matt-
The Following 5 Users Say Thank You to Cramer4918 For This Useful Post:
214Chevy (04-02-2023), camcojb (03-28-2023), Che70velle (04-02-2023), Goosesdad (03-30-2023), syborg tt (04-04-2023)
  #79
Old 03-28-2023, 07:12 PM
Cramer4918's Avatar
The seat cushion got tweaked a little over the jump area while putting it back in. I will be pulling it back out to address that and make it uniform again.
Finishing the wiring and fuel system will be next…. Hopefully.
Stay tuned!!🤙🏼
-Matt-
Old 04-02-2023, 08:06 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
The smiles on those kids faces says it all. Makes everything well worth it.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
The Following 2 Users Say Thank You to 214Chevy For This Useful Post:
Che70velle (04-02-2023), Cramer4918 (04-02-2023)
