Old 01-28-2023, 12:58 AM
need help need help is offline
sure wish these car forum would get as simple as FB, as FB is killing them. Yes FAST is miserable to get through to :-( however always helpful when successful. After Edlebrock bought next to impossible to get through........
Old 01-28-2023, 08:17 AM
If you want to search for an answer to a question the forums are far superior, with large databases of info that are searchable. If you want to ask a question social media works well, as long as someone can and will answer your question.
Bad Bowtie (01-28-2023)
Old 02-21-2023, 01:30 AM
Default no spark
Any suggestions welcome that are helpful. FAST 303000, FAST dual sync distributor and FAST E-6 ign controller. No spark, E-6 has red light when powered, no flash as should when cranking. the ECU shows all proper lighting and no fault codes on the Sportsman. All new system, have checked what I know and read in the trouble shooting guides, no luck...........
Old 03-24-2023, 02:58 AM
Default my fault
the E-6 and system was due to voltage not getting to it, MY FAULT..
The Following 2 Users Say Thank You to need help For This Useful Post:
andrewb70 (04-28-2023), camcojb (03-24-2023)
