Old 02-23-2023, 04:09 PM
68454RS's Avatar
68454RS 68454RS is offline
Originally Posted by Goosesdad View Post
To Simon's point, I think that vent line is going to fill with fuel, thus blocking the vent. What about if we come up with a cool body mod to hide it? It's 'glass right there, correct?
That's my concern as well and Yes, It's glass and as high as you can go
The Following 3 Users Say Thank You to 68454RS For This Useful Post:
andrewb70 (03-05-2023), Goosesdad (02-23-2023), syborg tt (02-25-2023)
  #22
Old 02-23-2023, 04:12 PM
68454RS's Avatar
What would be good is if I could find one that has a top inlet, then I could keep the line up high. Time to do some internet searching
The Following User Says Thank You to 68454RS For This Useful Post:
  #23
Old 02-23-2023, 04:21 PM
68454RS's Avatar
Something like this
Goosesdad (02-23-2023), Jimbo1367 (02-28-2023), syborg tt (02-25-2023)
  #24
Old 02-23-2023, 04:23 PM
68454RS's Avatar
I wonder if the one I have would work the other way around? Not sure why I assumed the ports went downward
  #25
Old 02-25-2023, 06:10 PM
68454RS's Avatar
You wouldn't think something as simple as adjustable seat tracks and seat mounting would kick your ass but, for whatever reason, it sure kicked mine. I had serious brain issues, overthinking it and trying to over engineer it. In the end, I simply mounted the sliders to the seats, which required nutserts in the seat frame then 1/2" spacers for the slide release/locking mechanism to operate. Then marked and drilled through both levels of floor aluminum. Cut and drilled out the 5/16" studs that came swedged in the sliders, replace with grade 8 - 1/4" bolts, grind the side of thick flat washers so they fit in the seat track channel, tack weld the head of the 1/4" bolt to the washer so that it won't spin and you can run a lock nut up on it from underneath without having to hold the head in the seat track yet isn't welded to the seat track incase you need to remove it. I didn't want the aluminum panels to crush down on themselves when I tighten the bolts so I made 1" aluminum spacers, cut the foam/heat barrier to accept the spacers and sealed them with foil tape. Like I said, Simple.
20230225_195549 by F G, on Flickr
20230225_195528 by F G, on Flickr
20230225_195729 by F G, on Flickr
20230225_195705 by F G, on Flickr
The Following 2 Users Say Thank You to 68454RS For This Useful Post:
camcojb (02-25-2023), syborg tt (02-25-2023)
  #26
Old 02-25-2023, 08:03 PM
syborg tt's Avatar
Very cool project.
marty-mj
68454RS (02-26-2023)
  #27
Old 02-26-2023, 08:05 AM
68454RS's Avatar
Confirmed I have the vapor canister upside down, the tubes should be up top. Thanks for bringing it to my attention.
Old 03-01-2023, 05:07 PM
68454RS's Avatar
re-did the vapor canister
20230227_201056 by F G, on Flickr
andrewb70 (03-05-2023), Goosesdad (03-03-2023)
  #29
Old 03-01-2023, 05:09 PM
68454RS's Avatar
Chipping away at the "to do" list, A/C unit mounted
20230301_190854 by F G, on Flickr
  #30
Old 03-10-2023, 06:26 AM
68454RS's Avatar
Found a spot for the Elec steering ECU. Had to cut and lengthen all the wire harness' but I think it's good to go now. Utilized the a/c bracket
20230309_185837 by F G, on Flickr
WSSix (03-10-2023)
