Old 07-05-2023, 04:42 PM
flyingv's Avatar
flyingv flyingv is offline
For any of you with an E67 from an 09' vehicle, here is what changes I made to finally get the C7 PWM fan to work.
1. I changed the OS from 09' CTS-V to an 09' ZR1
I did confirm through a document on the EFI Live forum that the 2 OS's are compatible.
*no matter what i did with the CTS-V calibration, I could not get a output signal from X3-49*
2. I changed fan settings to PWM Electric 100hz
*PWM EV 100hz did not work per the C7 calibration*
3. Fan State vs. Desired (all zeroes)
4. Output State vs. Control (all 1's)
5. Wired in AC pressure sensor @ X3-21, X3-57, & X3-37
Viola! PWM fan control works in the scanner!
The Following 3 Users Say Thank You to flyingv For This Useful Post:
camcojb (07-06-2023), cpd004 (07-07-2023), dhutton (07-06-2023)
Old 07-05-2023, 07:19 PM
andrewb70's Avatar
2. I changed fan settings to PWM Electric 128hz
Good information. Nicely done.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
Old 01-18-2024, 06:42 AM
samckitt's Avatar
samckitt samckitt is offline
Did you use EFI Live or HPTuners to change the OS?
Will it work without the AC pressure sensor or is that required?
Thx
Scot
86 Monte SS
LS2/T56 Magnum
