Old 08-07-2023, 04:55 PM
syborg tt's Avatar
Default Door Pull Hardware (( 08-04-23 ))
Sticking with the ARP theme I ordered more bolts.
These will be used to Red Pull Straps.
marty-mj
camcojb (08-07-2023)
  #2202
Old 08-07-2023, 05:05 PM
syborg tt's Avatar
Default Final Battery Wiring (( 08-05-23 )) Well Maybe ???
Trying to decide if I want to move the battery shut off to the top or leave it on the Side Posts.
I also noticed it was bent and preventing which was preventing it from actually killing the battery.
I added SAE washers to the top post wires so they would stop moving when I tightened the bolt.
I also put the battery on the Optima charger since it was dead.
Remy the Supervisor.
Kinda funny Mike and I were talking about this bolt the other day and yes it seized up while we were installing it.
marty-mj
Old 08-07-2023, 06:45 PM
I learned long ago to use anti-sieze on all stainless bolts and nuts. Learned the hard way that is.
Part of the reason I went to zinc plated bolts in my latest build, plus I like the OEM look.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
Jimbo1367 (08-09-2023), syborg tt (08-08-2023)
  #2204
Old 08-08-2023, 05:21 PM
syborg tt's Avatar
Default Inner Fender Bolt (( 08-05-23 ))
Just being safe here.
This inner fender bolt was protruding into the area near where the coolant hoses are. So just to be safe I shortened the bolt a little bit.
Whatever you do don't let that hit your hand.
I quickly pulled the bolt out before it fused it self to the clip.
and the good news is my hand is healing for the cut off wheel.
marty-mj
camcojb (08-08-2023), Roscoe03 (08-09-2023)
  #2205
Old 08-08-2023, 05:23 PM
syborg tt's Avatar
Trust me we put on anti-seize however I can confirm it was not enough
marty-mj
camcojb (08-08-2023), jarhead (08-09-2023)
  #2206
Old 08-08-2023, 06:31 PM
In the late 70's I had a 71 Camaro with a small block and 6-71 blower. I remember installing some Moroso anodized aluminum blower studs in the new Weiand intake by hand. Next day I went to remove them and several were like welded in place. Couldn't believe it, destroyed them getting them out. That's when I first learned about anti-sieze and the reason for using it lol.
Roscoe03 (08-09-2023), syborg tt (08-10-2023)
  #2207
Old 08-08-2023, 06:53 PM
andrewb70's Avatar
If you don't end up looking like the Tinman from the Wizard of Oz when you use anti-seize, you didn't use enough.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
Goosesdad (08-09-2023), syborg tt (08-10-2023)
  #2208
Old 08-08-2023, 08:56 PM
Andrew
  #2209
Old 08-10-2023, 09:35 AM
syborg tt's Avatar
Andrew
There was that one time that I went to bed and didn't think their was some left on my hand and I rubbed (picked) my nose.
marty-mj
Old 08-10-2023, 01:06 PM
Cramer4918's Avatar
Cramer4918 Cramer4918 is online now
Andrew
There was that one time that I went to bed and didn't their was some left on my hand and I rubbed (picked) my nose.
That’s almost as good as cutting up jalapeños and then having to pee and you forget to wash your hands before you do.
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following 2 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (08-10-2023), syborg tt (08-10-2023)
