Old 08-10-2023, 06:17 PM
syborg tt's Avatar
Default Classic Industries Door Panels (( 08-05-23 ))
Back on the door panels
I set up a table so I can easily work on them.
Need go modify a couple bolts
Time to see how close or far off the door handle hole is.
Once again I ran the bolts in from the backside so I could get an idea as to how far off they are.
The modified ARP bolts worked.
Door handle is in.
I am going to need to get a hold of D&R Classics as I can't seem to find the door handle escutcheons.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (08-10-2023), fleetus macmullitz (08-10-2023), Goosesdad (08-21-2023)
  #2212
Old 08-10-2023, 06:18 PM
syborg tt's Avatar
Originally Posted by Cramer4918 View Post
That’s almost as good as cutting up jalapeños and then having to pee and you forget to wash your hands before you do.
Oh my god this is the funniest thing I have ever heard.
marty-mj
Cramer4918 (08-10-2023)
  #2213
Old 08-10-2023, 06:42 PM
syborg tt's Avatar
Default Battery is charged and ready to start this car. (( 08-06-23 ))
I put the battery on the charger so I could start it up net weekend. It took about 20 hours to get to a full charge.
marty-mj
Old 08-10-2023, 07:00 PM
syborg tt's Avatar
Default Back on the Door Panels (( 08-06-23 )) AM Shift !!!
Back out in the garage tonight working on the passenger side door panel.
My new work table
Working on the water shield.
To make my life easier I raised the car and I was even able to set up a chair so I could sit and work on the door panel.
I am using the Eastwood Flexible Strip Caulk Bk 2lbs
I found this to be the best way to smooth out the caulk strips.
Added another strip to the top of the door.
I also added a little bit of Gorilla Tape.
marty-mj
fleetus macmullitz (08-10-2023), Goosesdad (08-11-2023)
  #2215
Old 08-10-2023, 07:07 PM
syborg tt's Avatar
Default It's late I m bored so out the Garage I go (( 08-06-23 )) PM Shift
Back out the garage I go.
Opps looks like I missed a nut .
Six months from now I am going to no clue where this wire goes to so once again I am adding a label.
marty-mj
camcojb (08-10-2023), fleetus macmullitz (08-10-2023), Goosesdad (08-11-2023)
  #2216
Cramer4918's Avatar
I don’t speak from experience, but one of the guys at my station actually did that. It quite a sight to see. 🤣🤣🤣
-Matt-
'61 Biscayne ~ AKA BISKWIK
Old 08-10-2023, 07:09 PM
Cramer4918's Avatar
I have an Optima Red Top. Hopefully I won’t need to invest in the charger to get mine fired up.
Loving the progress and updates, Marty!
-Matt-
The Following User Says Thank You to Cramer4918 For This Useful Post:
syborg tt (08-11-2023)
  #2218
Old 08-10-2023, 07:14 PM
syborg tt's Avatar
Default Opps my bad (( 08-06-23 )) PM 3rd Shift
Went for Tacos and I decided to go back out in the garage.
I noticed my battery shutoff wasn't working correctly and I think I found the problem. This is supposed to be perfectly flat
and as you can see it is bent which most likely was from me bending negative battery wires terminal.
I was temporarily able to straighten it and problem is solved and a new one is on order.
Hand is healing.
marty-mj
  #2219
Old 08-10-2023, 09:32 PM
65 347's Avatar
65 347 65 347 is offline
Matt
You should get one of these chargers regardless, the new optimas are not as good as the old ones, and you should use these charges if you leave the car sit for any amount of time.
Mike
The Following 4 Users Say Thank You to 65 347 For This Useful Post:
camcojb (08-11-2023), Cramer4918 (08-11-2023), jarhead (08-16-2023), syborg tt (08-11-2023)
  #2220
Old 08-19-2023, 09:05 AM
syborg tt's Avatar
Default OER Kick Panels Modifications (08-07-23) I am still out here
Drivers Side
Getting a bunch of little stuff done today was the goal.
I picked up some OER Kick Panels from D&R Classic the other day and today I am going to modify
them to fit. I can say these are a very nice piece and I highly recommend them.
Need to make sone modifications so I can get them in.
[IMG][/IMG]
Test fitting and they fit exactly how they are supposed to fit. Now I just need to make the modification needed so they work
around all of the wiring that I have added to this area.
Love this tape.
Cut Notes
I am going to take a little bit more off this side.
Once I am happy I will put some Tech-Flex wrap around these wires.
marty-mj
The Following 4 Users Say Thank You to syborg tt For This Useful Post:
camcojb (08-19-2023), Cramer4918 (08-19-2023), fleetus macmullitz (08-19-2023), Goosesdad (08-21-2023)
