Old 10-23-2023, 08:01 AM
andrewb70's Avatar
Default Is anyone interested in the ZF 8HP transmissions?
In the last couple of years I have been reading up on various modern transmissions swaps, like the dual clutch ZF transmissions as well as the ZF 8HP70/90 range.
Is anyone interested in the 8HP swap?
After LS Fest my buddies Tom and Brian drank the ZF 8HP KoolAid with me. Tom found a smoking deal on 3 take out 8HP70 transmission and he is starting to dig into them in preparation for doing the needed modifications to use the TurboLamik TCU.
These transmissions are simultaneously complex yet simple. Here is the main case after the valve body has been removed.
This is the valve body with a total of 9 solenoids.
This is the part that needs to be modified.
The shiny plate is the OEM TCU cover. That cover gets cut off and a PCB board gets soldered in place that allows the use of an externally mounted TCU.
I would be interested in hearing from people that are interested in this swap, especially with Holley EFI.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
fleet (10-23-2023), srode1 (11-03-2023)
Old 10-28-2023, 09:35 PM
andrewb70's Avatar
Today I got the images that compare a T56 with the Dodge 8HP70. This was a collaborative effort between myself, one of my customers, and Domi-Works. The images compare a Dodge 8HP70 with a GTO T-56. The 8HP70 is the gray outline and the T56 in black.
Here is the side view and you can see how the top profiles of the 8HP70 are about the same as a T56. Keep in mind that this will change a little bit with the 1" adapter installed, as the 8HP70 will sit one inch back.
This is the bottom view, and obviously the pan is wide, but the case profile is slim.
You can see that the case is slimmer in this top view.
This is the view from the rear...
The front view shows that the bellhousing overall diameter is about the same. This view also shows how much the 8HP pan extends down. I can tell by looking at this that the 8HP oil pan will be about 1" below a Holley 302-2/3 oil pan, which is very common for GM A-body LS swaps.
and lastly a couple of 3/4 views from two different angles...
I hope these images can help people better understand the fitment requirements. Judging by these pictures, I don't think that I will have to do anything to the tunnel in the Cougar to make this work. It actually looks like the transmissions mounts are very closely aligned.
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (10-29-2023), jarhead (07-11-2024)
Old 10-28-2023, 09:36 PM
andrewb70's Avatar
Here are the images comparing the Dodge 8HP70 with a 4L80e.
Looking at the side view, you can see that the top profile of the 8HP70 basically follows the outline of the 4L80e.
The bottom view shows how the 8HP pan has a much smaller foot print.
From the top view you can see that the 8HP is a little wider in the area where the bellhousing transitions into the main art of the case.
The rear view shows the depth of the 8HP oil pan in the rear.
From looking at these pictures, I am pretty sure that the 8HP70 will fit where ever a 4L80e fits. If your particular vehicle needs to have the tunnel modified to use a T56 or a 4L80e, then similar modifications will be required for the 8HP70.
It also looks like the transmission mount will be very similar to the 4L80e location and to the T56 location. I will be using a TCP weld together crossmember kit. It has a universal transmission mount pad that needs to be welded in place.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (10-29-2023), cla5675 (10-29-2023), WSSix (10-29-2023)
Old 10-29-2023, 06:01 PM
That's interesting, Andrew. Do you have any concerns about it holding up to the abuse the Cougar can give it?
Old 10-29-2023, 07:16 PM
andrewb70's Avatar
There seem to be plenty of swaps that have been done with the 8HP70 with similar or more power than what the Cougar makes. The 70 stands for the torque rating, which in this case is 700Nm, which is 516lf/ft. By comparison GM rates the 4L80e at 440lb/ft, and we know how durable those transmissions can be even in stock form.
I have two friends that are doing this swap at the same time. The other cars are a 66 Fairlane with a LSx454 and a 2004 BMW M3 with a LT1/LT4 engine combination. All three cars are in the 600-700HP range.
I actually thought there would be more interest here. This transmission is basically becoming the LS of the transmission world. There are adapter plates available for every popular performance engine out there, new or old.
Andrew
Instagram @dr__efi
My YouTube Channel
C1069 (01-08-2024), camcojb (10-29-2023), Ketzer (10-30-2023)
Old 10-30-2023, 07:29 AM
shinchane101 shinchane101 is offline
Exploring modern transmission swaps can be quite intriguing, especially when it comes to the ZF 8HP range. It's great to see the interest in the 8HP swap grow, and kudos to Tom for securing those transmissions and working on modifications. These transmissions do have their complexities, but the potential benefits are exciting. Looking forward to hearing more Futbol libre from those interested in this swap, especially in combination with Holley EFI. Keep us posted, Andrew
The Following User Says Thank You to shinchane101 For This Useful Post:
andrewb70 (10-30-2023)
Old 11-03-2023, 04:48 AM
srode1 srode1 is offline
Andrew
I'm following and interested for sure, following just not commenting. Guessing the ZF8hp90 would have the same integration solutions.
Old 11-03-2023, 12:34 AM
groovyjay's Avatar
groovyjay groovyjay is offline
We are using halltech to control the ZF8 behind an LS3. Amazing transmission.
The Following User Says Thank You to groovyjay For This Useful Post:
srode1 (11-03-2023)
Old 11-03-2023, 04:13 AM
andrewb70's Avatar
Care to elaborate on the technical details? I'm not aware of Haltech having any direct support for the 8HP except sending the necessary information to the 8HP over CAN.
How about some details about the hardware adaption and installation pictures?
What kind of car is it in?
Andrew
Instagram @dr__efi
My YouTube Channel
Old 11-05-2023, 09:54 PM
groovyjay's Avatar
Andrew
We are collaborating and sharing with halltech. LS3 engine and 8HP are in a 1982 celica rally cross car. We also have the 8HP mated with 900hp Barra engine which sits in a 1980 MB estate wagon
https://www.facebook.com/reel/573826411567754
