Old 11-03-2023, 04:48 AM
srode1 srode1 is offline
Originally Posted by andrewb70 View Post
I have two friends that are doing this swap at the same time. The other cars are a 66 Fairlane with a LSx454 and a 2004 BMW M3 with a LT1/LT4 engine combination. All three cars are in the 600-700HP range.
I actually thought there would be more interest here. This transmission is basically becoming the LS of the transmission world. There are adapter plates available for every popular performance engine out there, new or old.
Andrew
I'm following and interested for sure, following just not commenting. Guessing the ZF8hp90 would have the same integration solutions.
Old 11-03-2023, 06:20 AM
andrewb70's Avatar
Yes, the 8HP90 uses the same adapters and TCU. They are a little thicker in the middle of the case, but otherwise similar in dimensions to the 8HP70.
If the 8HP70 works well in my Cougar, I'll be doing a 8HP90 in my GTO.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
dhutton (11-03-2023)
Old 11-05-2023, 07:12 PM
andrewb70's Avatar
Today Tom sent me some pictures of the preparations that he is doing to the stock TCU in order to use the TurboLamik. This is the part that has to be removed from the valve body. Here it is sitting upside down and you can see the shiny plate, which is the case of the stock TCU. This top of this case must be cut off carefully by using e Dremel with a cut off disk.
Here is the stock TCU with the cover cut off. You can see how impressively small the electronics are inside the TCU.
Sadly, we can't use any of it, so all of the little wires that you to go from the circuit board to the pins have to be cut off and bent back.
Here is the Domi-works PCB board. It will get soldered in place to bridge the appropriate pins so that the TurboLamik TCU can be used externally.
Once the PCB is soldered in place, the little billet cover has to be glued in place. Tom found a local electronics repair place that will do the soldering at a very good price. We felt that this job was important enough to have a professional do it.
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (11-06-2023)
