Old 07-14-2023, 06:41 AM
68454RS's Avatar
68454RS 68454RS is offline
I received the ATI flex plate and had the same issue. Called the Torque converter company and their answer was to drill the flex plate holes slightly larger... called ATI and their answer was drill the flex plate holes a little larger.. Sooooooooo, 1/32" was all it took. Drilled each hole equally on a drill press in 1/64th increments keeping everything in alignment. The holes were exactly 29/64" and ended up 31/64"
Made a little progress, hopefully back in the chassis this weekend.
The Following 3 Users Say Thank You to 68454RS For This Useful Post:
camcojb (07-14-2023), Goosesdad (07-15-2023), syborg tt (07-15-2023)
  #52
Old 07-15-2023, 07:35 AM
68454RS's Avatar
Found some ambition last night and got it back in
camcojb (07-15-2023), Goosesdad (07-15-2023), syborg tt (07-15-2023)
  #53
Old 07-15-2023, 07:45 AM
syborg tt's Avatar
Looks awesome and now I am going out in the garage because of your post.
marty-mj
68454RS (07-15-2023)
  #54
Old 07-30-2023, 06:26 AM
68454RS's Avatar
Slowly chipping away at it..
Got the Derale trans cooler in and lines made
The Following 2 Users Say Thank You to 68454RS For This Useful Post:
camcojb (07-30-2023), syborg tt (01-16-2024)
  #55
Old 07-30-2023, 06:28 AM
68454RS's Avatar
Got enough hooked up to hit the key and make it come alive again
The Following 7 Users Say Thank You to 68454RS For This Useful Post:
camcojb (07-30-2023), dhutton (07-31-2023), fleet (12-26-2023), Goosesdad (07-31-2023), Jimbo1367 (08-10-2023), OLDFLM (07-31-2023), syborg tt (07-31-2023)
  #56
Old 12-26-2023, 07:16 AM
68454RS's Avatar
It's been a little while and just messing with it little at a time. Pulled the engine and trans again to get better access to the firewall and trans tunnel.
used a lot of elbow grease and mothers aluminum polish and tried for a mirror finish then coated with Sharkhide.
camcojb (12-26-2023), syborg tt (01-16-2024)
  #57
Old 12-26-2023, 07:18 AM
68454RS's Avatar
Swapped out the junk Koni's for some QA1 double adjustables
  #58
Old 12-26-2023, 07:19 AM
68454RS's Avatar
Finished the front wiring harness and added Second Skin Megablock insulation to the trans tunnel
  #59
Old 12-26-2023, 07:22 AM
68454RS's Avatar
Put the engine and trans back in, cut and welded flanges on the new Borlas then wrapped them with DEI Form-a-shield to hopefully reduce the amount of heat coming up through the floors.
  #60
Old 12-26-2023, 07:26 AM
68454RS's Avatar
Added a small panel to hold a bus bar, vintage air relays and circuit breaker. Bus bar gave me a great place to connect the vintage air and the Micro steering. Plus a stud for common ground.
camcojb (12-26-2023), jarhead (01-02-2024), syborg tt (01-16-2024)
