Old 01-20-2024, 11:12 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by srode1 View Post
So the ProVent 100 takes care of the oil tank vapors - how do/did you manage the valve cover outlets for vapors?
On LS engines the stock LS9 style valve covers have baffles and I think the LTs do also. We drill out the old 3/8 inch vent nipples and add a -8 AN nipple. This 900 - 1000 HP engine need a way to breath. If you don't get the vent large enough we have blow out rear main seals (Not good)(Big Fire). Also don't delete the factory PVC vent system. Air needs to move through the engine to get moister out.
A lot of air oil separators need to be drain manually, I don't like that. I like the Mann and Hummel's or similar that have previsions to drain back to he oil tank or pan. You don't need to remember to drain them.
Oil and or a lot of oil vapors that get into your intake will lead to preignition issue if it gets out of control. It is best to keep it under control.
Mark
Stielow Engineering
The Following 8 Users Say Thank You to Stielow For This Useful Post:
130fe (01-21-2024), andrewb70 (01-22-2024), DBasher (01-20-2024), fleet (01-20-2024), jmac (01-23-2024), Ketzer (01-22-2024), kwhizz (01-21-2024), MotorCityImpala (01-25-2024)
