Closed Thread
Old 02-08-2024, 05:54 PM
camcojb camcojb is online now
Very nice hardline work.
Old 02-08-2024, 08:44 PM
Blown353 Blown353 is offline
Mark, how do you normally run the brake hoses and wheel speed sensor wires to the rear axle for the ABS? Do you drop them all near the center section and run them along the axle like GM routed the brake lines on these cars originally, or you you drop each side down independently near the hubs like many late model cars with IRS do?
Just asking because I'm adding ABS to my car, and trying to decide how best to run things to the rear hubs and calipers. I'm leaning towards dropping both brake hoses and the speed sensor wires above the center section and then running them down the axle tubes to the rear hubs.
1969 Chevelle
Old 02-09-2024, 05:58 AM
clill's Avatar
clill clill is offline
Please remove the sticker from the crank pulley.
Old 02-09-2024, 06:43 AM
Stielow's Avatar
Stielow Stielow is offline
It came from China…
Stielow Engineering
Old 02-09-2024, 08:39 AM
The Following 4 Users Say Thank You to camcojb For This Useful Post:
Che70velle (02-09-2024), Ketzer (02-09-2024), thedugan (02-09-2024), zz430droptop67rs (02-09-2024)
Old 02-09-2024, 10:54 AM
fleetus macmullitz's Avatar
Dude!
Old 02-09-2024, 06:41 AM
Stielow's Avatar
The rear brake lines run down the sides outside the frame rail.
The wiring comes off the ABS module as twister pairs. Goes through a bulkhead connector the interior. Those wire join the rear compartment wiring harness that has the tail light, fuel pump…
The rear wheel speed wires (twister pair) pass through to a harness on the rear axle. At the connector we swap from normal wire (twisted pair) to a tougher encapsulation wire that goes the wheel speed sensors.
The OE style encapsulation wiring is hard to find and I had to purchase 1000 feet of it to get some. Nice stuff.
I’ll get a photo soon
Mark
Stielow Engineering
Roscoe03 (02-09-2024)
Old 02-10-2024, 09:53 PM
Mark
So you're dropping it at the sides near the hubs like a late model and then running a flexline right to the calipers and the wheel speed sensor wires right to the hub... thanks!
Makes more sense than running everything to the top of the center section and then down along the axle tubes like the 50 year old OEM layout-- especially when I would have to snake the lines and wires over watts link brackets, sway bar brackets, and then worry about maintaining adequate clearance between the hard lines and speed sensor wires to the tailpipes at full suspension compression. Dropping them at the sides keeps them out of the way of all of the rear end brackets and also the hot exhaust.
1969 Chevelle
Old 02-10-2024, 06:07 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
no ****, that's great. I have never been able to bend stainless lines well at all.
Scott from NJ
The Following User Says Thank You to BonzoHansen For This Useful Post:
camcojb (02-10-2024)
Old 02-10-2024, 09:55 AM
Stielow's Avatar
One more, fuel cross over.
I love the engine bay on this build. Nice mix of old and new.
We are back and forth on paining the LS engine to make is look like a 375 HP 396. Or leave it raw aluminum like a fake ZL1.
Stielow Engineering
BonzoHansen (02-22-2024)
Closed Thread
