Closed Thread
Old 02-09-2024, 11:54 AM
fleet's Avatar
fleet fleet is offline
Please remove the sticker from the crank pulley.
Dude!
Old 02-10-2024, 07:07 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Very nice hardline work.
no ****, that's great. I have never been able to bend stainless lines well at all.
Scott from NJ
The Following User Says Thank You to BonzoHansen For This Useful Post:
camcojb (02-10-2024)
  #273
Old 02-10-2024, 10:55 AM
Stielow's Avatar
Stielow Stielow is offline
One more, fuel cross over.
I love the engine bay on this build. Nice mix of old and new.
We are back and forth on paining the LS engine to make is look like a 375 HP 396. Or leave it raw aluminum like a fake ZL1.
Stielow Engineering
BonzoHansen (02-22-2024)
  #274
Old 02-10-2024, 05:44 PM
ScotI ScotI is offline
Well..... The ZL1 option was available in '69 so why not?
The Following 2 Users Say Thank You to ScotI For This Useful Post:
camcojb (02-10-2024), fleet (02-11-2024)
  #275
Old 02-10-2024, 07:41 PM
thedugan's Avatar
thedugan thedugan is offline
My vote is to stick to the original Hobbs Camaro theme. Orange motor to continue the theme.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following User Says Thank You to thedugan For This Useful Post:
  #276
Old 02-10-2024, 10:53 PM
Blown353 Blown353 is offline
The rear brake lines run down the sides outside the frame rail.
The wiring comes off the ABS module as twister pairs. Goes through a bulkhead connector the interior. Those wire join the rear compartment wiring harness that has the tail light, fuel pump…
The rear wheel speed wires (twister pair) pass through to a harness on the rear axle. At the connector we swap from normal wire (twisted pair) to a tougher encapsulation wire that goes the wheel speed sensors.
The OE style encapsulation wiring is hard to find and I had to purchase 1000 feet of it to get some. Nice stuff.
I’ll get a photo soon
Mark
So you're dropping it at the sides near the hubs like a late model and then running a flexline right to the calipers and the wheel speed sensor wires right to the hub... thanks!
Makes more sense than running everything to the top of the center section and then down along the axle tubes like the 50 year old OEM layout-- especially when I would have to snake the lines and wires over watts link brackets, sway bar brackets, and then worry about maintaining adequate clearance between the hard lines and speed sensor wires to the tailpipes at full suspension compression. Dropping them at the sides keeps them out of the way of all of the rear end brackets and also the hot exhaust.
1969 Chevelle
  #277
Old 02-21-2024, 12:31 PM
Stielow's Avatar
Starting to pull it back apart to paint some of the parts.
Mounted the Dakota Digital modules.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (02-21-2024), fleet (02-21-2024), Roscoe03 (02-27-2024)
  #278
Old 02-21-2024, 02:25 PM
Jay Hilliard's Avatar
Hey Mark,
Is the engine in the stock location or is it setback? Also what engine mounts are you using?
Thanks.
Jay
  #279
Old 02-21-2024, 02:44 PM
fleet's Avatar
Mark,
Since the car is not being painted, the thinking here is to stick with that theme and not paint the engine. #lessismore
Old 02-21-2024, 03:04 PM
Stielow's Avatar
We have used this template since 2002. I’ve lost track of how many time Matt or myself have used it. If it isn’t broke no need to fix it.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
BonzoHansen (02-22-2024), camcojb (02-21-2024), dhutton (02-21-2024), Fluid Power (02-21-2024), Roscoe03 (02-27-2024)
Closed Thread
