View Poll Results: Which block would you choose?
Dart Aluminum Block 30 73.17%
World Product Motownlite 11 26.83%
Voters: 41. You may not vote on this poll
Old 12-19-2006, 08:13 PM
jonny51 jonny51 is offline
Here is a Brodix........
Old 12-20-2006, 02:44 AM
Fastbowtie Fastbowtie is offline
That is VERY nice. I like it. Is everything standard on that as far as Distributor height intake height oil pan rail ect..?
Old 12-20-2006, 07:05 AM
JUSTANOVA JUSTANOVA is offline
that is beeyooteefull
Old 12-20-2006, 08:40 AM
Yes,including stock deck height but it's not a 427.
Old 12-20-2006, 10:16 AM
So what size is it? A 434 or bigger?
Old 12-20-2006, 12:47 PM
No it's 373,destroked 400.It is a twin turbo motor so no real need for big cubes.
Old 12-20-2006, 02:29 PM
nitrorocket's Avatar
You can easily make a 427" LS2 motor with an aluminum block. That will handle all the power you can throw at it. On top of that, an LS2 head with a little porting flows better then out of the box 18 degree heads...plus it's fuel injected!!
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 12-20-2006, 03:11 PM
rocketman's Avatar
Do what LS2 out flow 18's,Ls2's won't flow 350 cfm ported,I have set of Brodix 18's that out of the box flow 350 cfm,no port work out of the box.
Old 12-20-2006, 04:18 PM
The Brodix 18's do not flow 350 out of the box, suppose it depends on whos flow bench. All would have to be done on the same bench.
My Dart 18's flowed 330/260 @ .700 lift out of the box. My TEA ported LS1 heads flow 317/255 at only .600 lift. That is as much or more then my $4000 Dart 18 degree heads, with a factory $200 set of heads and $1200 worthe of valves and porting!
LS6 heads with porting 346/270 @ only .600 lift on a cheapy factory head!!
YOU CANNOT BEAT THAT WITH A STICK!
6 speed
Old 12-20-2006, 04:38 PM
rocketman's Avatar
Flowed them today at 700 lift they were 350/270.
