Old 03-06-2020, 06:39 AM
Stielow's Avatar
Stielow Stielow is offline
Some random build photos.
Stielow Engineering
Old 04-05-2020, 12:58 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Hey mark, what Master Cylinder, Brake Booster and proportioning system are you using on this car? Thanks
1967 Camaro RS
1969 Camaro coupe
Old 04-05-2020, 01:31 PM
Stielow's Avatar
The Detroit Speed booster and master. Prop valve Willwood off memory.
Stielow Engineering
Old 04-05-2020, 04:28 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
If you’re running ABS why are you using a prop valve? I’ve seen it on a few of your builds and with the C5 ABS I have for my car I know it controls bias. Is it just a back up fail safe you’re using it for?
Instagram- camaroaj
Old 04-05-2020, 04:32 PM
Stielow's Avatar
Yes I balance the system with ABS turned off then turn on the ABS. Yes it is an event of ABS system fault. Not likely but give me a piece of mind.
Stielow Engineering
Old 03-06-2020, 06:47 AM
Stielow's Avatar
Stielow Engineering
Old 03-06-2020, 06:57 AM
jarhead's Avatar
jarhead jarhead is offline
Amazing detail!
joe
Semper Fi
My 68 Torino
Old 03-06-2020, 07:35 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
I think Mark ought to build these for the rest of us - how about it Mark,are you up to do 2-3 millions of these for your followers?
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 09-10-2020, 01:35 PM
cwylie cwylie is offline
Is that an off the shelf DSE car roll bar or something custom?
Old 09-10-2020, 02:17 PM
Stielow's Avatar
Custom. Sled Alley made it
Stielow Engineering
