Old 02-18-2020, 05:30 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by Jimbo1367 View Post
Mark,
I think for your next build you should try sometihng a little outside your comfort zone and do a 70-73 Camaro RS . What would be your thoughts on something like that?
I think someone post this on every one of my builds....
My life coach told me a 2nd gen is a bad idea.
I did a 78 Blazer. That was a bit out of my Comfort zone. I had a blast building it but did not get too crazy.
Stielow Engineering
Old 02-18-2020, 05:48 AM
dhutton dhutton is offline
Life coach.... LOL. Is that Charlie?
Old 02-18-2020, 05:56 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Yeah Mark...do a second gen. Matter of fact, see the one I have for sale in the classifieds.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-18-2020, 07:23 AM
No his wife. LOL
Old 02-18-2020, 07:27 AM
I would really love to see what cool things the father of pro-touring would do to 2nd gen. Yeah, I have a 70, so it would hit closer to home. I love the blazer build. I didn't even know about it til the mag. article.
Old 02-20-2020, 10:27 AM
colorado80439 colorado80439 is offline
Working on the dry sump tank science project. This gets hidden in the passenger fender in the cowl area.
We run -8 lines off the valve covers to a -10. That runs to the top of the dry sump tank. Then the dry sump tank vents through a Mann and Hummel Air oil separator. The 5/8 line coming off the air oil separator runs to the induction tube.
The tall cylinder mounted to the dry sump tank is the transmission expansion tank. I run the vent line off the trans to the bottom of that tank. During open track days I have seen the transmission push out fluid when it is hot. Makes a mess. So now we add an expansion tank. Fluid get hot gets pushed into tank then drains back into trans when it cools.
I have to admit I've been lurking about looking to replicate this oiling/venting system. I think Donny was questioning this before, maybe on a different build, but I'm wondering how to route the oil return from the air/oil separator. Above or below the oil level? check valve? No check valve? Vent it to atmosphere?
Old 02-20-2020, 06:11 PM
Malitude was even further out of your comfort zone I'd say and that was a grand slam of a car in my opinion.
As much as I'd love to see your idea of a 2nd gen, I'm still amazed and appreciative of how open you are with all of your builds. Thank you, Mark.
Old 02-20-2020, 06:42 PM
jmac jmac is offline
Ok, another question for you Mark!
With the DSE subframe, what transmission cross member are you using?
I know the DSE engine mounts move the engine back 1.5 inches, and they say to use a stock style cross member. What are you using in this build, and what have you used in past builds? The closest pic I could see was on post #61, but it's far in the background and I can't really make it out.
Thanks again for your time and expertise!
Old 02-20-2020, 08:17 PM
will69camaro will69camaro is online now
I’ll let him verify but looks like (holley) hooker blackheart one to me.
https://www.holley.com/products/ls_p...parts/12626HKR
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-21-2020, 04:53 AM
Sled Alley Sled Alley is offline
The nipple off of the bottom of the air oil separator is mounted higher than the oil level and the line off of it returns low in the tank below oil level and does have a check valve coming right off of the separator
http://www.sledalley.com
