Old 06-17-2020, 06:02 AM
69hugger's Avatar
69hugger 69hugger is offline
Thanks Mark. I guess I need to find a "renegade" CNC guy. Any ideas where I can get a couple 3" x 1-5/8" CNC machined medallions made would be appreciated.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by 69hugger View Post
Question for you...Are these stock emblems you simply had chromed, or were they custom made in a different size or font?
I ask because just yesterday I contacted a custom emblem manufacturer about having some valve cover medallions made with "LS-3" engraved on them. I was told LS-3 is GM trademarked, and they were asked not to reproduce it. I was shocked.
That's odd...there are several companies selling Chevy emblem'd products.
Contact Shawn at EVOD or Jonathan at Sparc Industries. Either one of them will make you whatever you want made.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-19-2020, 07:20 PM
BDAZSVT BDAZSVT is offline
You might try Joel at https://www.jccustomscnc.com/
Old 06-30-2020, 06:16 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Need Updates...… !!!!!!!!!!
Old 07-03-2020, 05:26 AM
Stielow's Avatar
Stielow Stielow is offline
The car is at paint and the Dutchboys are doing a great job.
Stielow Engineering
Old 07-03-2020, 05:30 AM
Stielow's Avatar
Default Camaro LT5
We dumped the engine at Katech. Runs solid and made 915 HP and 870 ft*lbs. We ran into an issue with the HP Tuners tuning capabilities. We need access to some tables that do not have. It is dropping boost at 6400 RPM. I’m sure the engine will make 950 HP once we get that sorted.
Stielow Engineering
Old 07-03-2020, 07:16 AM
colorado80439 colorado80439 is offline
Originally Posted by jmac View Post
Looks great! What are all the black bits painted with?
I was wondering as well!
Old 07-03-2020, 12:03 PM
payne payne is offline
Yeehaw. Will you be running traction control and what tire will you put the power down with? All the way to R7s, or will you use a more streetable tire?
I make 702rwhp on E50 in my daily driver (2nd gen CTS-V, manual transmission) and 580rwhp on 91octane.
Even with drag radials and 4200lbs, the car will light off the top of 3rd gear on ethanol. On Pilot Sports it'll sometimes light off the top of 4th, which is... entertaining if you stay in it.
I can't imagine a 200 TW hooking below 100mph at 950hp and low 3000lbs
Old 07-03-2020, 09:18 PM
Stielow's Avatar
No traction control, all by just straight up driver control. I have road raced a lot of cars with more power on 200 tread wear tires with no issues. I would not let anyone else drive it but it works just fine.
Yes you can do roll on burn outs in 3 rd gear! Good stuff!
Stielow Engineering
Old 07-04-2020, 10:11 AM
garickman garickman is offline
Probably one of the best emblem guys in the business.
https://www.instagram.com/radmachining/
Greg
