Old 12-25-2020, 09:02 PM
fleetus macmullitz's Avatar
He could out run us in a Camray...
Agreed!
Old 12-26-2020, 03:37 PM
Rodknock's Avatar
Rodknock Rodknock is offline
Just amazing. Almost makes me want to got supercharged instead of TT. That's ok, I have time!!
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 12-29-2020, 04:01 PM
cpd004's Avatar
cpd004 cpd004 is offline
We are dry building the whole car this time before paint. Matt is putting the front clip on it now to finish the engine bay.
Just finished the dip stick for dry sump tank.
Reassembling the front end
In this pic, is the long L bracket attached to the radiator custom made or where did you source it?
Thank you.
1971 Firebird
2017 SS
Old 12-30-2020, 05:41 AM
Stielow's Avatar
Stielow Stielow is offline
Thank you.
Sorry I don’t understand your question. The picture is of the dry sump tank.
The radiator was made by C&R. The car was modified a lot to make it fit.
Stielow Engineering
Old 12-30-2020, 06:48 AM
cpd004's Avatar
Sorry...this long upper bracket here.
Thanks.
1971 Firebird
2017 SS
Old 12-30-2020, 08:02 AM
Stielow's Avatar
Thanks.
That comes from C&R.
Stielow Engineering
Old 12-30-2020, 08:54 AM
just_a_69 just_a_69 is offline
Hey Mark. Great build per usual...
I’m wondering how you check the oil with the dry sump tank in that location. Do you use a custom dipstick through the fitting on the firewall? Would a sight glass welded on the side of the tank work?...
Thank you for all the information and ideas you provide to this forum.
Old 12-30-2020, 03:42 PM
Stielow's Avatar
It has a dip stick
Stielow Engineering
Old 12-30-2020, 04:24 PM
Stielow's Avatar
LED bulb trial testing.
Many LED bulbs are too bright as running lights (Gordon’s Camaro)
I wanted LED bulbs closer to stock brightness for running lights.
Stielow Engineering
Old 12-31-2020, 03:02 AM
69Toronto 69Toronto is offline
tailights look great, are those bulbs for the stock socket or an LED panel?
thank you
