Old 03-07-2021, 09:19 PM
Blown353 Blown353 is offline
Originally Posted by Ns RS View Post
Mark what’s the verdict on the tilton in comparison to the dyad clutch? Car looks great
Very interested in your verdict as well, I'm also eyeballing the Tilton ST-246 for my build but haven't seen too many reviews for them.
I had a Mcleod RXT on the shelf but sold it after driving a few that I installed in other people's cars, didn't care for how grabby they were when taking off and also didn't care for the amount of floater rattle in neutral. Hoping the Tilton is better in both areas.
Recently installed a Monster LT1-S twin disc in a supercharged 2006 GTO, and it's a really nice clutch. Drives like a stock GM clutch in terms of effort, engagement smoothness, and noise, but it should-- it's a heavily reworked GM clutch.
Trying to decide between the Tilton ST-246 or a Monster LT1-S triple disc in my car.
1969 Chevelle
Old 03-08-2021, 03:27 AM
Stielow's Avatar
Stielow Stielow is offline
The Tilton is dead quite with the clutch pushed in. The pedal force is about the same as the DYAD. The launch is smooth and chatter free most times. If you lug it and don’t give the engine a few revs it can chatter a small amount. If adapted my launches a little and add 500 rpm and it is smooth.
So far the hi rpm reserve is very good. I have not tracked it yet but form the little bit I have drove it I like it. (I only have 200 miles on the car).
DYAD 7.25/10 rating. Negative rattles at idle when it has some miles on it. It too can chatter sometimes. Need a custom throw out bearing. Great high rpm reserve. Work awesome on the track. No issues.
Tilton 8/10 rating Does not rattle at idle. Does not need a special throw out bearing. Had a small chatter at a very soft launch. I have not tracked it yet.
Mark
Stielow Engineering
