Old 11-27-2024, 12:34 PM
syborg tt's Avatar
Default Kore3 Wilwood Electric E-Brake Drivers Side (( 2024 10-19 ))
This one is for you Skip.
I finally installed the rear brakes and the electric e-brake.
Brackets are on and look fantastic
E-Brake installed
Temporally shimmed with washer and when I have time I will have the Guys at High Speed Welding machine me an actually shim.
Pretty Bolts have been installed and yes the Tin Man **** is coming out.
At some point I am going to paint the rotor hat area.
marty-mj
fleetus macmullitz (11-28-2024), Goosesdad (12-06-2024)
  #2462
Old 11-27-2024, 12:41 PM
syborg tt's Avatar
Default Moving over to the passenger side (( 2024 10-19
I have no clue how I used all of these tools on the drivers side.
Yes I have issue's
This side should go much faster.
ARP Hardware
Crazy !!
marty-mj
The Following 5 Users Say Thank You to syborg tt For This Useful Post:
89 RS (07-13-2025), camcojb (11-27-2024), fleetus macmullitz (11-28-2024), Goosesdad (12-06-2024), Rodknock (12-01-2024)
  #2463
Old 11-28-2024, 10:41 PM
fleetus macmullitz's Avatar
Excellent update as always, Marty.
Old 12-01-2024, 07:32 PM
Rodknock's Avatar
Rodknock Rodknock is offline
I want to do an electric e-brake on my 69 with the Heidts rear IRS, but they are awful proud of it. Over $1,000 from Heidts for the parts to do it. I might try to buy the calipers and make my own brackets, then all I would need is the actuator and cables.
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
The Following 3 Users Say Thank You to Rodknock For This Useful Post:
camcojb (12-01-2024), fleetus macmullitz (12-03-2024), syborg tt (12-02-2024)
  #2465
Old 12-02-2024, 10:41 AM
syborg tt's Avatar
Get a hold of Tobin @ Kore3 as he might be able to help you.
marty-mj
Rodknock (12-02-2024)
  #2466
Old 07-08-2025, 10:08 AM
Default Dude…where's your car?
https://youtu.be/rLsUo6seUss?si=MJT0orrORbxx4dxp1
Old 07-08-2025, 10:22 AM
syborg tt's Avatar
Hey Skip
Well, I am back on it and the more I dig into the issues with the trans. The more I regret it.
So the trans is garbage and the Wagner motor is also junk. It’s leaking everywhere and the hypothesis is the a few of the rings are bad or broken.
I am going to pull the trans and give it to a different trans shop to look at it. Even though the I plan to buy a new engine and transmission.
If you look way back in the beginning of the build I used this set up to get the trans out.
Since the trans pan is beautifully powder coated I am going to put a stamped steel pan on for removal.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
89 RS (07-13-2025), camcojb (07-08-2025), fleetus macmullitz (07-08-2025)
  #2468
Old 07-08-2025, 10:31 AM
Great to hear from you Marty, but very sorry to hear of the issues.
Roscoe03 (07-15-2025)
  #2469
Old 07-08-2025, 10:48 AM
Cramer4918's Avatar
Cramer4918 Cramer4918 is online now
I’m so sorry to hear about your misfortune, Marty. It seems like when you get a couple steps forward, something jumps up and sets you back ten. Hopefully you can get it sorted quickly and without breaking the bank. Good luck to you!
-Matt-
'61 Biscayne ~ AKA BISKWIK
The Following 2 Users Say Thank You to Cramer4918 For This Useful Post:
camcojb (07-08-2025), syborg tt (07-08-2025)
  #2470
Old 07-08-2025, 11:12 AM
dhutton dhutton is offline
Sounds like maybe you could use a bit of a laugh…
The Following 5 Users Say Thank You to dhutton For This Useful Post:
89 RS (07-13-2025), camcojb (07-08-2025), jarhead (07-29-2025), Roscoe03 (07-15-2025), syborg tt (07-08-2025)
