bracing for the side mounted hinges. the gate will open on the passengers side and hinged on the drivers side.
I see no benefit of having the gate drop down 6 inches onto the ground. More so it'd just wreck the paint.
So one sided barn door opening it is...
The Following 4 Users Say Thank You to bk2life For This Useful Post:
Been working the side swinging hinge for my tailgate. It’s not 100% where I like it, but its opening and closing. The hinges are made for a thick door, not a thin tailgate. OS I have to work some sheet metal to cover it and make it look good.
Not sure if I said it above but I'm trying a new powder coater. I sent off oil pan, transmission case, trans pan and front cover to be coated. If they look good, ill send more parts to the shop. Eventually all chassis and parts will be powder coated red.
I dropped off my lower control arms to my buddy and had him press out the ‘stock’ lower ball joints and installed ‘tall’ style ball joints to help with alignment and getting another ½ inch drop out of the suspension.
I order some new upper control arms that will allow more lift from the air bags. I might use them and make a jig to modify them to work more with this type of suspension, and not the ‘drag race’ set up they are made for.
The Following User Says Thank You to bk2life For This Useful Post:
