Old 01-15-2025, 07:44 AM
rickpaw rickpaw is offline
Please let us know how the new Dakota Digital Velocity cruise control kit works. I'm been thinking about adding cc to my car (with Holley EFI/DBW) and this seems to be the solution.
Thanks.
Tu Ho
The Following 3 Users Say Thank You to rickpaw For This Useful Post:
130fe (01-15-2025), camcojb (01-15-2025), dontlifttoshift (01-15-2025)
Old 01-19-2025, 07:44 AM
Stielow's Avatar
Stielow Stielow is offline
Thanks.
I finally got to drive the car a bit before Christmas with one nice dry sunny day. With a little tinkering I was able to get the cruise to work fine. I ran out of the day to do a full evaluation. I used it on the hiway at 80 mph with now issues and also at 50 mph on a normal road. Work great. It is a little clunky at 40 mph but who need cruise at 40? I was just doing a sweep of speed.
Once the weather breaks in MI I’ll get out and try it more.
I’d does have a cool Bluetooth app that allows you to make set up changes. Over all another great Dakota Digital product.
A couple example set up screens.
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
camcojb (01-19-2025), dontlifttoshift (01-20-2025), kwhizz (05-19-2025), rickpaw (01-22-2025)
Old 01-19-2025, 09:10 AM
Thanks for the info Mark. I plan on getting one for the Chevelle.
Old 01-25-2025, 09:10 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Mark can you please share the part number for the upper radiator hose. I have recently installed the Holley Mid Mount and the Acdelco 22842M hose is a bit short.
72 Camaro RS:SOLD
68 Camaro:
Old 01-26-2025, 05:05 PM
AJG87 AJG87 is offline
I believe Mark posted this already; D71267 upper hose.
The Following 2 Users Say Thank You to AJG87 For This Useful Post:
camcojb (01-26-2025), Ketzer (03-30-2025)
Old 01-27-2025, 09:41 AM
Stielow's Avatar
Thanks, I have not had a chance to look it up.
Mark
Stielow Engineering
camcojb (01-27-2025)
Old 01-27-2025, 10:36 AM
72Z/28's Avatar
Thanks a lot man. I do not know how I missed it. Just placed an order from Rockauto, and hopefully it fits perfectly.
72 Camaro RS:SOLD
68 Camaro:
The Following 2 Users Say Thank You to 72Z/28 For This Useful Post:
AJG87 (01-27-2025), camcojb (01-27-2025)
Old 02-20-2025, 08:33 PM
mdavidthomas mdavidthomas is offline
Someone earlier in the thread asked about the fuel tank vent system. You replied that you would show it once you had it worked out. Do you have a solution for this now on the Hobbs Camaro?
Also, wondering what the bore size of the 2002 F-Body clutch master cylinder is that you are using on your builds?
Thanks,
mdavidthomas
