Old 02-13-2025, 05:53 AM
HEEP's Avatar
HEEP HEEP is offline
Old Brackets
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
The Following 2 Users Say Thank You to HEEP For This Useful Post:
camcojb (02-13-2025), syborg tt (02-18-2025)
  #252
Old 02-13-2025, 07:43 AM
ScotI ScotI is offline
Are you using the BBU hubs as well?
  #253
Old 02-13-2025, 11:37 AM
Che70velle's Avatar
Nice work Bill, as always.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
  #254
Old 02-13-2025, 12:37 PM
HEEP's Avatar
The hubs are a set from Kore3.
Bill
My Build Thread;
camcojb (02-13-2025), syborg tt (02-20-2025)
  #255
Old 02-16-2025, 03:22 PM
HEEP's Avatar
Little more work this weekend. Got the BIGBRAKEUPGRADE brackets for the front, and installed. Everything looks good now.
Still Waiting on a bent metal for the trans tunnel.
Thanks for looking
Bill
Bill
My Build Thread;
The Following 3 Users Say Thank You to HEEP For This Useful Post:
andrewb70 (02-16-2025), camcojb (02-16-2025), syborg tt (02-18-2025)
  #256
Old 02-20-2025, 07:05 PM
syborg tt's Avatar
Love the brakes and I think I will eventually get a set.
marty-mj
camcojb (02-21-2025)
  #257
Old 02-21-2025, 05:08 AM
HEEP's Avatar
The only problem waiting, is that they don't make the LH backing plate anymore. I had to find some on EBAY, and also found the calipers at the same time.
My goal was to use as many factory parts as I could in this build.
Thanks for looking.
Bill
Bill
My Build Thread;
The Following User Says Thank You to HEEP For This Useful Post:
  #258
Old 02-21-2025, 12:16 PM
andrewb70's Avatar
One thing that you might want to keep in mind is that when you use a fixed caliper there is going to be some pad knock back when using a hub with tapered bearings. Modern cars that use fixed calipers have hub assemblies.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (02-21-2025), HEEP (03-03-2025)
  #259
Old 04-09-2025, 07:23 AM
HEEP's Avatar
So a little update. Been working on the coil mounting and the routing of the wiring harness. Also, the breakdown of the harness, and how they plug into the computer.
My plan is to run all the wiring for the ECM and engine through bulkhead fittings to ease the process of installation and removal if that ever needs to happen.
Copied the Stielow mounting of the coils like he did on the Hobbs Camaro.
The family decided to get me the Lokar big block style valve covers for my birthday. My son was in on leave, and made that happen.
Ended up having to get another intake to make the Lokar valve covers work with my injectors. There just wasn't enough room to plug them up.
Bill
My Build Thread;
camcojb (04-09-2025), Roscoe03 (04-09-2025)
  #260
Old 04-09-2025, 07:48 AM
Intake swap..... From what to what?
