Old 12-31-2006, 06:06 PM
Efi69Cam Efi69Cam is offline
Originally Posted by 3kidsnotime
Gen 5 and 6 heads are the same, the diff between a gen 5 is a non roller engine in 96 the engine was changed to a roller engine with raised lifter bores and noted by a composite 6 bolt cover the heads are the same casting number the crank rods pistons are as well, both 5 and 6 are priority main oiling gen 5 and 6 use the same head gasket 4 does not If it is any need I can snap some pics of 5 and 6 heads I have about 45 take off sets, do your research its your money. That is based on production gm iron heads, If you take the gm performance aluminum heads the new ones they will work on all blocks except gen 7 8.1 series, those heads as all ne aftermarket alum bbc heads have small water passages but added material to seal the block on 5 and 6 motors if using them use the correct head gasket.
http://www.sdpc2000.com/faq/kbhowto.asp?mt_node=360
Some interesting reading for you.
The blocks might take the same gasket but the water holes in the gen 6 deck are smaller, and thus the mark 4 heads work.
Old 12-31-2006, 06:53 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
Sounds like I need to recall about 2300 engines Literally and go back so school I think the question was will a 5 or 6 head work on a 4 block?? not a 4 head working on a 6 block.... I might be wrong but I thought that was the question...... I am not trying to get a flame war going on Im trying to help a person with a project with known facts and also years of every day experience building gen 5 and 6 engines
Old 12-31-2006, 07:51 PM
No flame war. I just was confused by what you said about the gen 6 block so I did some more digging. My point is that there are more differences between the gen 5 and 6 than what you listed. The biggest is the change in the deck, it looks nothing like the gen 5, and takes mark 4 heads.
My experience is that the problem is 4 heads on a 5 block, I think the other way, 5 or 6 heads on a 4 block has never come up as most of the late heads are junk. The heads I recommended, the ZZ 502 heads, are of the universal design you mentioned. I have a set of these bolted onto a 1970 454 with no coolant leaks.
I too am just trying to help out. If the guy who asked the question has a 79 vintage block, the ZZ502 heads with their 110CC chambers, universal deck, and large oval port design are an excellent choice, and at the price offered with matching manifold by the other guy, are a smoking deal.
Old 12-31-2006, 08:04 PM
The SD catalog you quoted is not all that correct as well the only 6 block with a fuel pump boss is the over the counter replacement service block that is why the water passages are smaller and fuel pump boss added gm made a block to sevice all the engines with that one. The production gen 5 and 6 454 vortech engines in trucks from 1991 to today in the 8.1 have not had a fuel pump boss the only ones I have with them are service replacements. the aftermarket industry has made added deck surface to the heads with a small water passage to fit 4 5 6 blocks the new gen alum heads from gm performance are just Edelbrocks with gmperformace on them. Good question who is the largest purchaser of engines from GM I might post that its a good question
Old 12-31-2006, 08:18 PM
The 99 burb 454 I have in the garage has the smaller coolant holes, no fuel pump boss.
The largest customer of GM engines is likely Mercury Marine.
Old 12-31-2006, 08:19 PM
correct mercury marine
