Old 04-05-2005, 02:10 PM
BuddyP's Avatar
BuddyP BuddyP is offline
Default Anybody here with 1st Gen Camaro's in MI, OH or IN?
Anybody from Lower, MI, northern IN or NW Ohio? Would like to find someone that has a similar setup that I am planning on doing on a 1st gen Camaro.
Let me know what you have and location
Buddy P
[email protected]
Old 04-05-2005, 06:50 PM
67cam406 67cam406 is offline
BuddyP, I am from Lawrenceburg, In, Which is near Cincinnati, Oh.
I am just starting to work on My 67 camaro. Not sure if I would be able to help you, Just saying HI, I Could Let you know What Ia m planning to do, I have got a lot a ideas from Here and another Site. What are you Planning to Set your car up like. Street/Pro-touring?
I Do a lot of Work in Ann Arbor, MI and Sylvannia, Oh.
Drop me a line anytime.
Kevin
1967 Camaro (stock)
Pro-touring Project
Old 04-05-2005, 06:51 PM
markus markus is offline
I live in NW Indiana, what are you looking at doing? Mines still a work in progress.
Old 04-05-2005, 08:02 PM
BuddyP's Avatar
Hey guys, was just checking to see if anybody was close enough that I could meet up and learn some things and see it actually done on a car.... Anyway, here's some basic plans for me at this point... It is going to be a street/Pro touring setup. The car right now is stripped down to bare shell and subframe is completely disassembed. I plan on having the shell dipped to strip it off clean (alkaline dip, a place in Toledo, OH does it). Suspension upgrade plans at this point is new Bilstein or KYB shocks all around, 1 1/2" drop in the rear, 2" drop in front, Hotchkis 1 1/8" sway bar, and Poly bushings all the way around. Going to put in a tight steering box (around a 2.5 lock to lock). Have a Wilwood Dynalite 4 pistons front disc kit already, will be putting discs in the rear as well. Would like to go with 18" x 8" wheels up front and 18" x 9.5" wheels in back if I can get away with it. Want to keep stock rear fender wells. Motor will likely be a SB like a 383 or similar (might just try doing a LS1???). Undecided on transmission at this point... possibly 4 speed Manual or may just stick with an Auto. Other than the normal body work and paint that's about the most of it except for upgraded seats and instrumentation.
Markus, I'm in Angola, IN (very NE corner)
Buddy P
[email protected]
