Old 01-31-2007, 08:39 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Originally Posted by Efi69Cam
Apparently the engines that used this cam sensor oil drive were controlled by the same computer that 98 LS1 Camaros and Corvettes used. They have coil per plug ignition and throttle by wire. They also used a 24x crank reluctor wheel. The combination of these cam and crank sensors would allow any gen-6 BBC to be controlled with an LS1 PCM, and have COP ignition. This might be a budget alternative for some folks.
Good to know. Thanks for info!!
Brent
