Old 02-06-2007, 05:19 PM
jh99 jh99 is offline
Default Tire Mounting Question
I just got a set of Intro wheels with the smooth lip. I have mounted many tires and different wheels, but never anything with a smooth lip. I know the tire has to mount from the back of the wheel, so how do you clamp the wheel without scratching the smooth lip??
Old 02-06-2007, 11:30 PM
DriverzInc DriverzInc is offline
What kind of tire mounting machine are you using? You really have to be careful, use alot of solution, I use alot of soap and water.
Old 02-07-2007, 06:26 AM
sinned's Avatar
sinned sinned is offline
The wheel gets mounted upside down in a rim clamp machine clamping the reverse method with rim protectors. This is NOT a job you want to attempt without a newer machine AND expereince.
Dennis
Old 02-07-2007, 02:35 PM
4mm 4mm is offline
Exactly, the rim protectors are plastic sleeves that are the shape of the steel clamps that hold the rim of the wheel. I just had mine mounted today and they used the rim protectors. The wheels had to be mounted upside down since they are reverse lip (smooth lip): not one scratch on any of them.
Old 02-10-2007, 11:54 PM
Thanks for the help. I have a Focus rim clamp machine with the plastic covers. I just wanted to make sure that is the proper way to do it. I would be sick if I scratced my new wheels.
