Old 02-11-2007, 10:17 AM
Sales@Dutchboys's Avatar
Default Coil Pack relocation?
What have you guys used? or know of?
dutchboyshotrods.com
269-823-2967
Old 02-11-2007, 10:51 AM
Steve1968LS2's Avatar
What do you mean by "relocation"?
As in "not in the stock location" or "can't be seen any longer".
I used the Katech system. It only moves them a bit but they are "relocated"
Old 02-11-2007, 10:52 AM
Like where you dont see them any more. But I really like your set up as well
Thanks for the reply
269-823-2967
Old 02-11-2007, 11:27 AM
camcojb camcojb is online now
Tony (Nineball) from LS1Tech mounted his on the back of the head(s) with a homemade bracket. I am planning something similar.
Old 02-11-2007, 11:31 AM
Thanks.
269-823-2967
Old 02-11-2007, 08:12 PM
ironworks's Avatar
We made brackets to attach to the custom nasty performance valve covers. It requires custom plug wires but also kind hides the injector harness and Idle air circuit plumbing. I like them
http://i56.photobucket.com/albums/g1...1-27-07011.jpg
Old 02-12-2007, 03:31 AM
I like that.
269-823-2967
Old 02-13-2007, 07:08 AM
Maximum Bob Maximum Bob is offline
Default Paradise Valley High School
We have smoothed our firewall, and the students have relocated the coil inside the car under the dash.
Summit carries a firewall bulkhead type of plug wire fitting, that can be mounted anywhere on the firewall.
Ours is centered on the distributor comming out of the firewall.
Old 02-13-2007, 09:22 AM
TravisB TravisB is offline
thats easy on normal SBC.......an LSx has 8 coils. I doubt you would want 8 bulkheads in your firewall
Kenny Davis Hot Rods
Old 02-14-2007, 01:23 PM
LMAO....sorry didnt realize it was an LSx you were reffering to......duh
